Cosmic Space Artist
Hey everyone,
Has anyone managed to successfully setup their A1200 surf squirrel scsi interface running latest workbench?
I am running the genuine copy of 3.2.2.1 along with the custom 3.2.2 roms . (EHIDE.DEV) added.
if I allow the surf squirrel to install by its installer which applies older versions of software such as Mount and more, then I get the Cd0 mounted and everything works until i reboot and then it will only boot to a grey screen. I removed the startup sequence to eliminate that but still grey screen.
I suspect its to do with the older software incompatible with the latest versions, So I use the installer to avoid installing the older versions but then it will not work,
I have tried allsorts manually configuring the Cd0 to match scsi ID, and only installing squirrel scsi.device by extracting it from the installer, but It requires all files or nothing.
When I opt for keeping newer files of Mount, setpatch, fastfile system the scsi device will not work at all.
am i right in thinking the device is non compatible with 3.2.2.1 ? its worth noting my PCMCIA CF card works perfectly, with the cfd133 and Fat 95
many thanks,
Jamie.
many thanks,
Jamie.
