Sold A1200 with TRA1200 68020@28Mhz 4/8MB RAM 4GB CF - Australia
voyager_1701e
Maitland, NSW
Hi All,
I have the following available for sale...
Amiga 1200 system.....
Amiga 1200 1d.4 mainboard with Kickstart 3.1 ROMs installed ( I believe this one was likely manufactured under Commodore, not Escom)
TRA1200 expansion, featuring 68020 @ 28Mhz (http://www.bigbookofamigahardware.com/bboah/product.aspx?id=145), with either 4 Mb or 8Mb RAM (Ill supply both SIMMs. The reason I don't simply give you 8Mb is I understand it is not PCMCIA compatible with the installed 3.1 ROMs and 8Mb, so you need to use 4Mb if you want to use the PCMCIA slot). So the system RAM is 2Mb Chip and either 4 or 8Mb Fast installed...up to you! Let me know if you also want a set of 3.0 ROMs, but other than the minor RAM issue they are rather useless.
4GB CF hard drive, with 3 partitions. Installed with Classic Workbench (http://classicwb.abime.net/index.htm - 3.1 ADV 2 8). This also has numerous applications such as Directory Opus installed, along with many AGA games and demo files (run via the excellent WHDLoad).
It will be supplied with OS disks, new PS/2 optical mouse and PS/2 adaptor (can be a little temperamental on 1st boot, but fine after that), an original Amiga ball mouse (for a backup), an older joystick to get you started and an A500 power supply (heavier, but provides more power than the A1200 supply...although not likely an issue using the CF as a hard drive).
Some technical details....I have replaced all the capacitors, and there was no damage to the mainboard from those that did leak. The keyboard and floppy drive are both "new old stock" from a current European Amiga dealer. The CF drive and adaptor are likewise new. The casing shows a very very minor amount of yellowing (but maybe I'm being too picky about it!). I have tested the machine for more than 2 hours, running processor tests, games and demos without issue. I have run the composite video port, the RGB port (I would encourage you to only use the RGB port, as the composite output is quite poor...I can suggest options if you contact me), both mouse and joystick port works fine and also checked the external floppy port, so all functioning normally. I haven't tested either the serial, parallel or PCMCIA port as I have nothing to test them with. I have no reason to believe these ports have any issues.
Please note I have advertised this elsewhere.
Looking for $500, but will consider near offers. Postage will be at cost or pickup from Parramatta / Penrith NSW (or maybe other arrangements can be made)
Now splitting...
A1200 with 4GB CF - $300 AUD or near offer
TRA1200 accelerator with 4mb & 8mb stick (card max is 8mb RAM) - $110 AUD or near offer + shipping
TRA is available for international sale (although postage may make it uneconomical)
