A2000 cannot see disk on other controller
Tomse
RISK is good
Denmark
Copenhagen
yay, finally my A2000 arrived.
(Rom 2.04, Workbench 2)
(pictures to come up later ;-))
I got 3 SCSI-II disks
2 on a GVP 030 combo
and 1 on a California Access: Malibu controller
now, when I boot with all 3 drives attached, I can only see the 2 disks on the GVP, and not the one on the Malibu.
I guess this due to that both my drives are called the same? HD0
I just need a confirm of this.
They have alot of software that I need to look through before formatting them.
AndyLandy
Acceleration!
Treasurer
Southampton
Firstly, I'd pull the GVP card & disks out and see if the other controller plays ball. That'll give you a few pointers. :)
Tomse
RISK is good
Denmark
Copenhagen
forgot to mention that I already did that..
the malibu controller and disk is alive and kicking ;-)
things work fine, just not when both HD0 are connected
AndyLandy
Acceleration!
Treasurer
Southampton
It's almost certainly going to be because they share a partition name. I'm fairly certain you can rename the partition without damaging the data, but I'd double-check that first. There's an option in HDInstTools to specify the volume label, so change one from HD0 to HD-whatever.
meega
Elite ranking
Volume label is just the name as seen on Workbench (I think), rename it with Rename.
I don't think it will help - you need to change the actual identifier (HDToolbox or whatever). I also think you can do that without losing the data, as you aren't really altering the partition (just what it gets Mounted as), no promises though.
TheCorfiot
Out in the Wild
Corfu
Regarding 'device' identifiers I know that KS3.1 will add an '_0' automatically to the similar named device and allow both to be seen.
Type in 'info' at the CLI to see what devices have actually been mounted.
TC :)
Andy & Meega are right: you'll not lose the partition just changing its identifier. Only changing the size of it will be an issue if you do.
Tomse
RISK is good
Denmark
Copenhagen
thanks for the infos,
I didn't get a chance to try some of the things you wrote..
it came up and couldn't read the rahd0 device which it somehow got to be called..
anyway, I reformated the drive and about to softkick it to 3.1 and install OS3.1 on it.. it's a 20Meg drive only.. 3½" fullsize some old company called Rodime
whiteb
Mostly Harmless.
Melbourne, Australia
Victoria
You can change its Name (HD0, SDH0, whatever you want) without trashing the Partition. You are merely changing its name, not the physical layout of the partition, which *IS* data fatal.
Tomse
RISK is good
Denmark
Copenhagen
as you can see from my previous post, it's too late ;-)
