Sold A2090 scsi/hd controller with manual
  • Thread starter Thread starter Exilent
  • Replies Replies 4
  • Views Views 1329
Exilent
Netherlands
Noord Brabant
A2090
[TABLE="class: basedata"]
[TR]
[TD]Company
Commodore, USA [/TD]
[TD]Date
1987[/TD]
[TD]Amiga
A2000, A3000, A4000
[/TD]
[TD]Interface
Zorro II
[/TD]
[TD]Autoconfig ID
514 / 1
515 / 3
[/TD]
[/TR]
[/TABLE]
  • SCSI and ST-506 controller
  • supports seven SCSI and two ST-506 devices at once
  • the SCSI drives are controlled by the WD 33C93 IC
  • the ST-506 drives are controlled by the Zilog Z80B CPU
  • the 33C93 chip can be controlled by either the 68000 (default) or by the Z80
  • DMA transfers are provided by the custom Commodore 8727 IC featuring a 64 byte FIFO buffer
  • the Z80 CPU has 2 kB RAM to buffer commands from the Amiga, 8 kB PROM with driver routines and 1 kB RAM for storage of variables
  • cannot autoboot
  • does not support the SCSI Direct protocol
  • does not support partitions and drives larger than 256 MB
  • the ST-506 interface does not support 16-head drives
  • 50 pin internal SCSI connector
  • DB25 external connector
  • hard disk activity LED connector
  • on Zorro III machines the card only works if the driver and all the buffers are loaded into chip RAM
  • A-Max II driver (hddisk.amhd)
Asking 25 euro + postage.
UNTESTED!
