I recently bought a PPS Mercury accelerator from another member, and installed it in my 3K.
It seems to work, until I turn the DCache on via SetPatch or Sysinfo, and then it'll hang after basically the next thing I do (machine won't boot at all with my existing sequence because it runs setpatch at the beginning)-- sometime after which point the machine hard-locks.
I'm running 3.1 roms and 3.1 dos / wb.
I doubt the dcache is damaged (could it be?)- I assume I am missing something elementary, like a library or setpatch update.
again, this happens even when I boot without startup-sequence. :S
EDIT: For instance, if I type SetPatch, then LoadWB, the system hangs.
Turning on DCACHE in sysinfo, then pressing the "memory" button in the gui produces a hang.
Turning on dcache via the CPU command, then opening aexplorer produces a hang.
If I loadwb, then enable the cache, the machine will hang after I click something.
If the dcache is on, the machine just wont run.
Thanks!
Thanks!
