A3000d+ks3.0+os3.9: Problems with deneb
LTAC
FRANCE
South of PARIS
Hello,
I've installed the great DENEB on my AMIGA:
- A3000D 030@25Mhz + 2MB CHIP + 4MB FAST;
- KS3.1 / OS3.9 / HDD 100MB
- multicard reader;
- DENEB (with lastest firmware);
- Buster 09 (too old?? :()
- all others cards were removed !
All perfect until the WB screen:
- my Compact Flash card appears as expected, but soon as I double-click on icon: my computer freeze, as the mouse.
Maybe someone has already had this concern, thank you for helping me.
Version of Buster may be is causing this problem???
Thanks you very much.
Best Regards,
Move the Deneb jumper to Zorro-2 position. This will cure the issue.
Also search on EAB and Amiga.org. I saw people with this issue before.
LTAC
FRANCE
South of PARIS
Yep I'm reading the thread with SAVE2600...I also have the crash of 'TRIDENT' when when I try to run it (MUI is installed).
Thank you.
---------- Post added at 18:07 ---------- Previous post was at 18:02 ----------
...and when I move the Deneb jumper to Zorro-2 position: my USB multicard reader is OFF.
jvdbossc
HypnusBE
Belgium
Antwerp (province)
Ltac,
I did have that problem as well, but I have version 11.
I just hope you did not ignore my previous post?
Give me this evening, I'll have to write proper english first and add some linky's.
I don't know if it's help but Michael also did not understand and offered a lot of help, but I got tired of the many procedures to follow and gave up and settled with zorro II. He posted me this, on my A4000 it did not work together with the mediator, but on the A3000 it worked!
- get latest Poseidon V4.4 and Luciferin from Chris Hodges website, and
install them. They replace old versions from the installation FlashROM
- set the jumper from RES to ROM, disabling the FlashROM, and setting the
DENEB into normal operation mode
- boot you machine
- start Luciferin, ignore the warning on the ROMOFF jumper, setup
an empty list, choose and bootloader (one which can be disabled by MMB
or LMB) and upload this empty list to FlashROM.
This clears all FlashROM contents, also the intro.
---------- Post added at 13:31 ---------- Previous post was at 13:05 ----------
@Ltac, oh the software is here:
http://www.platon42.de/poseidon.html
The version delivered on the deneb to install was older in my case..
http://www.platon42.de/files/usb/PoseidonV4.lha
http://www.platon42.de/files/usb/Luciferin.lha
So might save you the time?
__________________
Very proud owner of:
A1000-A500-A2000-A600-A1200-A3000D-A4000D
Got what I wanted at last!
LTAC
FRANCE
South of PARIS
Thank you for helping me jvdbossc.
Ok now I've new version of POSEIDON & LUCIFERIN.
DENEB don't works on Z2 mode :(
Nothing detected on USB port :(
I'm tired of all these tests and I would make a complete initialization of the DENEB to start for a clean install. How please?
DENEB tested also on my A3000 with Buster 11 => nothing !! I can't have the virtual drive "DenebInstall" :wooha:
Ltac,
- boot you machine
__________________
jvdbossc
HypnusBE
Belgium
Antwerp (province)
What finally cured my problem is to start luceferin while the deneb2 was in ZII mode and flash the rom with nothing, or something funny like the A1000 startup sound after previous info.
I know it's quite... But once it is working, very handy and cost cutting...
Hold on, I'll post some pics..
I am just hoping I started a thread with pics, you did position the usb cable connectors on the cards right :huh: If not make sure know :unsure:
---------- Post added at 19:48 ---------- Previous post was at 19:43 ----------
This is how to connect the connectors
http://img693.imageshack.us/i/jvb4978.jpg/
The thread is here, once you get to enjoy it :)
https://www.amibay.com/showthread.php?t=6687
---------- Post added at 20:00 ---------- Previous post was at 19:48 ----------
Ok, sorry no RTG yet on that machine, still need to P&P a seller :(
Luceferin:
I did not understand at all at first, but the local, flashrom, are not in line with the needed usb functionality, the are extra freebies to put it in a way... but as you can guess the modules on the left they are just extra toys, not needed at all.
What happens if you put nothing in local tab and press upload = blank.
After that it started working properly .. I only have the A1000 jingle module in for now, and the noclick:whistle:
I hope you understand a little, I took the pics to compensate my lack of good english
LTAC
FRANCE
South of PARIS
Hi jvdbossc and thank you for your reply.
There is no problem with LUCIFERIN: I make all you write and no problemo.
The problem was half solved:
- works ONLY with DENEB jumper in RESCUE mode;
- with LUCIFERIN: I choose QUICK SETUP/POSEIDON USB";
- I change TOOLTYPES of TRIDENT software: "REGISTERMODE" + "SAVE";
- I create a false "TRIDENT.cfg" at "envarc:mui/";
- TRIDENT software crach anyway but I can use a part of it :crazy:
- I make a save: after this TRIDENT software crach definitivly and I must reboot :confused:
- after reboot I launch TRIDENT software and I make a RESTART: all USB device are recognized :biglaugh:
- after reboot: all USB devices are recognized at start :)
But I must stay in RESCUE mode!!!
Please, if I forgot something: HELP ME. Thank you
USB device recognized:
- USB Keyboard - T'nB - ACK-2080UM (100mA);
- Multicard reader "RYVAL" USB2 - ALL-in-1 Card Reader;
- USB TenKey Pad (with 2ports HUB): USB numerical pad => can't have correct caracters;
- ARCHOS Gmini 400 (HDD 20GB);
- HAMA (46945) 8-in-1 Card Reader;
jvdbossc
HypnusBE
Belgium
Antwerp (province)
You have tried (if the rom is empty) almost every thing done by me :(
The only thing that I did and helped a while was to take a second jumper and put the rom off. So zorro II and ROM off. The intro is gone I hope? If not you did not clear the rom.. My machine stopped with the intro..
Maybe you need to take it up with Michael. The deneb is a supported product. He learned me most of this stuff..
Since it's a more recent product there seem to be no power users on here ..
I too had complaints not getting out of config mode, maybe move a zorro slot up or down?
It's working at my place after all this... I hope somebody else can add something, I have not much more to share...
Maybe revision 7 is no good - but that is only guess work, non educated guess work..:help:
