Sold A314TD
  • Thread starter Thread starter Koolvin
  • Views Views 587
Koolvin
London
A314 Trap Door version for sale. This is for the A500 or A500plus
Just one for sale- £140 plus postage PayPal Friends and Family
From GitHub: https://github.com/niklasekstrom/a314
  • a314fs is a file system that is mounted in AmigaDOS as a device, PI0:
    The volume in PI0: is called PiDisk:, and is mapped to a directory in the RPi.
  • pi is a command that lets you invoke executables on the RPi from the AmigaDOS CLI. For example, if your current working directory is on PiDisk: and you run "pi vc hello.c -o hello", then the vc program (the VBCC cross-compiler) is executed on the RPi with the given arguments. It will cross-compile “hello.c” into the Amiga executable file “hello”. The resulting binary is immediately accessible through the a314fs.
    You may also launch Interactive applications using the pi command, such as "pi mc -a" which will run Midnight Commander. Running pi without any arguments is equivalent to "pi bash" and will present you with a bash prompt from the RPi.
  • PiAudio lets the RPi stream audio samples directly to the shared chip memory, from where Paula plays those samples. PiAudio is integrated with ALSA on the RPi so that any program that plays audio through ALSA can be used, i.e. "pi mpg123 -a amiga song.mp3" plays song.mp3 using the program mpg123 to the Amiga.
  • RemoteWB works by moving the Workbench bitplanes over to the chip memory on the A314. This requires that the A500 has at least a 8372 Agnus. During drawing of each frame on the Amiga, the RPi reads those bitplanes, encodes them into a GIF image, and transmits that image to a web browser through a web socket. The web browser in turn, returns key presses and mouse movements back to the Amiga through the same web socket. In effect, this becomes a web browser based remote control application, comparable to VNC but with near zero performance impact on the Amiga CPU!
  • VideoPlayer is a simple program that displays a sequence of images on the A500 by letting the RPi write bitplanes directly to the shared memory (this again requires that the A314 memory is chip memory, and not "ranger" memory).
  • ethernet is a SANA-II driver that forwards Ethernet packets to the network interface of the RPi. Together with an Amiga TCP/IP stack this provides network access to the Amiga.
