Closed A4000D case x 1 , A3640 x 1 , Faulty A4000 mainboard x 1
voyager_1701e
Maitland, NSW
Available for purchase are the following:
Amiga 4000 case with power supply. Power supply works normally, case is in quite good condition, although the facia and floppy drive are yellowed. I havent tried the floppy in a while, but I am sure it works, but is supplied as is. The case has the plastic mainboard protector sheet, the Zorro riser support bar, the floppy drive cage and rear slot cage. I'm asking $150AUD + pp fees + postage. Regretfully, postage out of AUS to anywhere in the world is going to be very expensive and likely not economical. The total weight, including packaging should be 8kg. An example to the UK standard airmail is $200AUD! More than the case! ****SOLD****
A3640. Has been repaired by Anthony Hoffman. It has been upgraded to 3.2. It has a 68040 @ 40Mhz installed, but the standard 25Mhz oscillator is fitted. I did try a faster oscillator (I cant recall which speed I tried), but I suspect it wasnt stable. The switch fitted was to support the faster oscillator. I am supplying it without the heatsink. I know I have the heatsink here somewhere, and will provide it I can find it! I can remove the switch if the buyer requests it. I have used the card for many hours as is without issue (I did sit a couple of temporary heatsinks when using it though!). I am asking only $200AUD +pp fee + postage due to its repaired nature, but I have total faith in its operation. The item weighs only 175g, so under 500g 1st postage cost step. An example to UK standard airmail is a much more reasonable $18AUD ****SOLD****
Faulty A4000D mainboard. Regretfully I have to admit I took a completely good board and faulted it! I removed the IDE GALs and fitted sockets and updated GALs. Whether coincidence or not, I cant recall, the board no longer functions after that. Only a black/grey screen. The CAPs have been replaced, as you can see in the photos. The board was damaged around the battery, and that had been repaired successfully, even the RTC circuit worked. I cant recall exactly but the audio circuit had some corrosion damage repaired as I changed a couple of ICs and the CAPs, and socketed Paula...but that all worked correctly post repair. The CIAs are socketed as after the board ceased functioning as someone wanted them, but then I later got some more to try get the board to work and fitted sockets. I really cant recall why I socketed Gary. The 3.1 roms supplied work fine, as does the Buster 11. Will include the pictured 2MB SIMM. I dont know if I can give any more info than all that! Asking $150AUD + pp fees + postage. It weighs in at 700g, maybe can sneak it under 1kg with postage meaning an example of postage to UK/Germany is $39AUD standard airmail.****SOLD****
Pls declare interest and PM, any questions are welcomed
These will be listed elsewhere.
Tormentor22
Germany
RLP
Declaring interest for A4000 Board. Can you post photos
voyager_1701e
Maitland, NSW
Bleagle11
France
Aude
Hello,
If available, Declaring interest for A4000 Board.
Can you post photos.
$150AUD + pp fees + postage for France Cost total ?
Thank's
voyager_1701e
Maitland, NSW
Hello,
Thank's
Could you be more specific? Photos 3,4 and 5 are of the A4k board in post 1.
The board itself weighs around 350g (I put 700g in the original listing, dont know why!), regretfully with packaging it will come in above 500g, meaning jumping to a higher postage bracket.
To France, 500g-1kg postage will be $39.10 regular airmail, $46.10 tracked airmail and tracked/insured would be $58.20
Please PM if interested
thanks,
Bleagle11
France
Aude
Hello,
$150AUD + $46.10 tracked airmail :Cost total ?
Pm
Thank's
