A4000D Replacement Battery questions...
merlinkv
Ukraine
Kyiv
I have a Noob question...... :oops:
After reading some posts about A4000D batterys. I'm thinkg to change the battery for one "coin" type.
I see some A4000D mobos with Lithium CR2032 3v, but the "original" and new barrel batterys are 3.6v. :blink:
So, the CR2032 3v works fine? Not problems with different voltages?
merlinkv
Ukraine
Kyiv
@davideo
With this batteries, you need desolder/solder each time you want to replace? Is not better a socketed coin battery?
I ask, because I have some sockets (from old/broken mobos) for CR2032 batteries...
davideo
I look like Gizmo
Staff member
Administrator
Staff Moderator
Treasurer
Boston, Lincs
These are rechargeable and should hopefully last as long as the caps do - so you can do both jobs together when they need doing :D
If you use a standard CR2032 you'll need to do the battery hack to stop your Miggy trying to recharge a non-rechargeable battery - otherwise you'll get a big bang from your Miggy that you didn't expect :oops:
Dave G :cool:
merlinkv
Ukraine
Kyiv
@davideo
Thanks for the info m8.
Last question :oops:
Just desolder the older one and solder the new? (I think is not needed any "hack" at the mobo, right?)
I go to buy four units of the recommended batteries....
Thanks again
davideo
I look like Gizmo
Staff member
Administrator
Staff Moderator
Treasurer
Boston, Lincs
If you get the same battery as I did - then just unsolder, clean up and solder new battery - easy peasy (y)
If you want to use a standard CR battery then you'll need a diode, battery holder and battery. Otherwise it's the same as above with the exception of fitting the diode between the battery holder and MB.
Andylandy did a thread on fitting this type of setup on his 2000. See here https://www.amibay.com/showthread.php?t=3542
Dave G :cool:
davideo
I look like Gizmo
Staff member
Administrator
Staff Moderator
Treasurer
Boston, Lincs
You're welcome.
Dave G :cool:
