Drgonzo
Hi all,
First post and hoping for some sage advice. I recently got back into the Amiga after many years away. I came across a lot which included an A4000D with a warp 040 which is now (indirectly thanks to Cosmo I'm told), an 060 Warp Engine with a 75 MHz rev4 060. As expected, due to the FPU it's not very stable. I'd done a ton of research and understand my stock (and legal) 3.1 ROM needs an exec.library update for the system to work right. I'm on the fence about buying the Cloanto 3.x rom kit since I'd like to keep the workbench.lib in the rom for max stockness. Same for going to 1MB ROM. I tried to cook my own 3.1 with just a new exec.lib and it seemed to all fit and compile, but booting winuae with it is hit/miss. When it does boot the version does check out. I've been trying to get my 4000 soft kicked with it to test, but none of the kickers seem to work. Warpkick, skick, rekick, etc... Skick keeps telling me there's no ram to load it into. Is that because all I have is 32bit ram on the WE? Or because the WE says it doesn't support MAPROM? I'd thought about buying an eprom kit but I'd like to know if my cooked rom is good and hardware viable before I make the further investment. If I do break down and buy Cloanto 3.x, can anyone confirm that it should be stable with my setup?
Full specs:
A4000D
WE w/Cosmo adapter and rev 4 060 @75 MHz
128 MB on WE
16 GB SD card via IDE adapter
IDE CDROM
Picasso II
OS 3.9
Possibly will install my Prometheus once the rest is stable and see about locating a Voodoo 3 card ��
Thanks in advance for any help!
Dr. Gonz
Full specs:
A4000D
128 MB on WE
IDE CDROM
Picasso II
OS 3.9
Dr. Gonz
