hi
i'm looking for a front panel of the AT escom A4000T + the led/key-lock holder
So a full bezel with the door and a key! Wow, Softhut closed down sadly!hi
Have you got the door?i think it is hard to find , but i can try , i got the tower case , but no full frond and the panel for the 3 led's and keylock
He has a PC tower that is exactly like A4000T tower only with different front.Have you got the door?
www.amibay.com
i have no door , got only a 3d file of the door ,Have you got the door?
yes , the tower i have buy is for 99% the same as the escom at tower of the a4000t ,you looking to put a A4KT front bezel on a 486 ?
yes i say it to get the tower for the reamiga 4000t board , something you must say something to get it for a good price , so i get the tower that i can use for the a4000t board , i can leave the front on it , but it is better if i find a real a4000t frond with the panel for the led'sah yes I get that, but in your wanted thread you said you was looking for this case to put your 486 mobo in, so thought you might be creating a crazy frankenstein!
It looks really good. The slanted grills are more Atari ST than Amiga in styling but it's smart! I'd stick with it and customise it if I was you especially if everything fits! It's a shame it's a bit heavier but other than that a good find!the tower i got all are the same , only the psu are bigger then the a4000t from at , the front of myn a4000t fit on the pc tower
This towerised A2000 has the C= vertical grills but in many ways the slants look better IMHO!the tower i got all are the same , only the psu are bigger then the a4000t from at , the front of myn a4000t fit on the pc tower
It is owned by a guy on the The Cave (RMC) Discord called sozzledandrews. You'd have to ask him.
