SLIM 8mb fast ram / IDE + CF card adaptor + 4gb CF card + special HC version 68000 cpu
With the HC68000 CPU the inline resistor packs are NOT required for replacement eeprom kick 3.x or switcher
The great thing about this combined cpu - ram - ide is it fits under the keyboard without any modification required.
( you need to solder 2 wires to side expansion ) details from MKL below and a rom with scsi.device recommended 3.1 or higher (tested ok on 3.1.4)
£65 ( Was £80 )+ P&P
Hi. First, pin 1 on cf adapter is on the pin row closer to the cf card - so if the connector cable has pin one marked in plastic, it will be closer to the cf slot. (If adapter were connected directly to ide board, the cf slot woukd be over the cpu)
You need to connect int2 and ovr to main board.
These should be marked on silk screen (on bottom)
and in this picture http://www.mkl211015.altervista.org/ide/brd425i.png
2/int2 and ovr and the 6th pin is gnd (or not if only 5 pins are on board)
