Hi all,
Hopefully someone has had the same issue I'm having and will point out that I'm doing something wrong or stupid. So I have a gotek which I want to connect externally and use a boot selector to swap it from df1 to df0.
I purchased a boot selector and an external cable (links below)
Boot selector - http://www.ebay.ie/itm/122327373472?_trksid=p2060353.m2749.l2649&ssPageName=STRK:MEBIDX:IT
External cable - http://www.ebay.ie/itm/272363110859?_trksid=p2060353.m2749.l2649&ssPageName=STRK:MEBIDX:IT
I didnt follow the instructions that came with the cable as they are the bending the pins on CIA to swap the SEL0 and SEL1.
I put in the boot selector with just my internal amiga floopy connected and the switch is position 1 and workbench boots fine. Plug in the gotek externally (s0 jumpered) and I just get the gotek LCD coming on and the Amiga purple boot screen, no internal disk activity from the floppy. If I run the gotek in place of the internal floppy the gotek works. If I flip the switch to position 2 to turn the gotek into df0 and cut off the internal floppy I just get a gray screen - no video is outputted.
KS2 (37.175)
Tired on a500 rev5 and rev6a
Any ideas?
KS2 (37.175)
Any ideas?
