A500 disk drive daisy chain cable
T_Hairy_Bootson
Workbitch 1.3
Melbourne
Moved as requested.
I am not sure such a cable existed. I know some external drives had a connector on the back so you could add another drive to the chain. But I have never seen a cable like the one you describe.
SaviorX
VCCUG
Canada
Calgary, Alberta
i have 3 externals for my 500 and that is exactly how they work..they chain off each other.....each drive has a cable and a connector...
Slayer
New Zealand
Dunedin
hmmm, I would have thought at least one of your external drives would have a through port? Simply plug the one without into the back of the one that does? CPU > DF1 > DF2
as T_Hairy_Bootson is saying
If there was such a cable it would have some interface built into the plug that simply acts as a dual throughport I would think also...
cosmicfrog
The 1 That Ribbits
Rating - 98.8%
81   1   0
Potteries
I have never heard of a cable such as this iether
so time to get some floppy drives with thru conector
ghoshy2010
Rating - 0%
0   0   0
manchester
thank you for the reply
thank you for the replys. ill check the rear of each drive. but im sure theres no connection on the rear of each drive.
the cable by the way is not to diffrent from what we add harddrives to IDE cable but with the connectors for the drives to connect to. have seen numerous posts and quotes about it all over the web. but thank you guys for moving the thread and replying..
davideo
I look like Gizmo
Staff member
Administrator
Staff Moderator
Treasurer
Boston, Lincs
