hi all, this is the diagrom output:
Detecting if we have a working raster: DETECTED
Detected Chipmem: 512KB
Detected Motherboard Fastmem: 0KB
Basememory address: $0006CCDE
- Parallel Code $f9 - Detected memory in use, we now have a stack etc
Set Start of copper (COP1LCH $dff080): Done
Starting Copper (COPJMP1 $dff088): Done
Set all DMA enablebits (DMACON $dff096) to Enabled: Done
Set Beam Conter control register to 32 (PAL) (BEAMCON0 $dff1dc): Done
Set POTGO to all OUTPUT ($FF00) (POTGO $dff034): Done
- Parallel Code $f8 - Starting up screen, text echoed to serialport
Amiga DiagROM V1.0 - 27-Oct-17 - By John (Chucky/The Gang) Hertell
To use serial communication please hold down ANY key now
OR click the RIGHT mousebutton.
Holding down the LEFT mousebutton will force serial on and turn off screen
forcing stuff to run in fastmem if avaible
then stuck... swapped every single chip with another board except the agnus because i don't have another 8375. Any help?
