Hi there. After months of collecting hardware, trying many configurations out of which almost none really worked with Micronik's busboard, I've ended up with this:
* Commodore A500 rev 6a OCS without CPU (Micronik turns A500 into early A2000 made in Germany that need CPU removed to work with Blizzard 2060)
* A501 - gives RTC and 1 MB Chip RAM
* Indivision ECS
* Kickstart 3.1
* Blizzard 2060 - 68060/50 MHz, 128 MB Fast RAM
* Cybervision 64/3D, 4 MB
* Ariadne Ethernet
* HDD SCSI IBM 4.3 GB
* CD-ROM NEC 40x
* Black Amiga Technologies mouse
* Mechanical keyboard from the early A2000s, it uses NMI key switches, has left Commodore key and red Caps-Lock LED, I rehoused it into CDTV keyboard case.
* Dell 20" Display
* Cheap Creative speakers
As you can see this Amiga works nicely under AmigaOS 3.9 with BB2.
If you're interested how it looks inside here is a shot:
You can see it's quite tidy inside, only 3 cards visible (Turbo, RTG and Ethernet), you can see the new PSU and my ATX power adapter.
Here's closeup at the power adapter:
Indivision ECS partially covered by SCSI ribbon and HDD LED wire:
And closeup at cards:
Plans for future? Get Daneb USB 2.0 and probably replace Ariadne with faster USB NIC, maybe also some AHI Sound Card - we will see what can I find
* Indivision ECS
* Kickstart 3.1
* Ariadne Ethernet
* CD-ROM NEC 40x
* Dell 20" Display
I like that very much.
