Closed ACA 500 and a ACA 1233 for trade...
britlord
Rating - 97.9%
46   1   0
usa
Michigan
Hi Amigos,. I have here is ACA 500 and a ACA 1233 (they can work together). Both are still sealed in their boxes. I'm not looking to sell but to trade both for a Derringer 030, Mega midget or other 030 accelerator for my A500..
If interested please Pm me with what you have..
Oh. I am waiting for the plastic enclosure to arrive, so you will get that too.......
Thanks for looking....
A500DaBest
Canada
BC, Surrey
I am going crazy! I just cannot get my mind into figuring out why would you want to trade out two good hardware that have way more feature, brand new, more valuable in my opinion for an outdated card like Derringer 030? The derringer 030 card does not even support the latest kickstart 3.1 and on top of that it does not give you the easy ability to transfer files into the Amiga 500 like said ACA500 for example.
No more horrible serial null modem! No more having to use AExplorer and waiting for 10 minutes to transfer to Amiga 500 via serial modem and risk the chance that it may or may not afterwords.
I don't get it.
britlord
Rating - 97.9%
46   1   0
usa
Michigan
You don't have to get it, and it's not the the derringer 030 that I was offered. You see I want it internal. Not external in the end. Also, I'm fitting a real hard-drive on top of the shield in my 500+ (20GB), so I'll dump all the files on it using Winuae first....
Have anything to trade for it....
A500DaBest
Canada
BC, Surrey
You are right, I don't get it and I don't have to get it :) And if you told me it is non of your business, I would not be offended and I would agree it is not my business. I do hope you find what you are looking for and you have a successful transaction. Just wanted to finish off by saying I know exactly what item you are talking about:
http://www.bigbookofamigahardware.com/bboah/product.aspx?id=63
Processor:030@16Mhz, 030@25Mhz, 030@33Mhz, 030@40Mhz or 030@50Mhz (Platinum Version)
FPU:Optional 68881 or 68882 (PGA) from at 25Mhz or 50Mhz
MMU:Internal
Max Ram:32MB
Ram Type:1x72pin SIMM slot. EDO RAM can be used, although it's not taken advantage of.
The Derringer plugs into the CPU socket of the A500 and A2000 and also works with the A1000 providing you have a socket extender to provide the board with enough clearance. The 68000 is placed on board the Derringer which allows the machine to be switched back to 68000 mode for compatibility with old software. The card has support for copying the Kickstart into 32bit Fast RAM for an additional increase in peformance however this may not work correctly with newer versions of Kickstart such as V3.1. In order for the machine to see the RAM onboard the Derringer, a small command must be added to the startup-sequence, directly after the SetPatch command called D3. An earlier version of this card may have been released which used an 020 instead of an 030.
britlord
Rating - 97.9%
46   1   0
usa
Michigan
That sure is a nice board , and you are entitled to your opinion... Do you have one though??
DutchinUSA
Unites States
Wisconsin
There were quite a few people who were hoping for an internal solution when Jens was working on the ACA500, it didn't happen. :)
locnar77
Canada
Alberta
kipper2k is working on one like the vampire 600
or you could do this
http://www.ppa.pl/forum/komentarze/30509/aca500-aca12330-indivision-ecs-w-srodku-ami
