The ACA1221LC accelerator offers an additional 11.2 MB of fast RAM, IDE speeder, and a guaranteed clock of 26.67 MHz. I checked it also at 40MHz, but I didn’t do extensive testing as I don't need that speed. This accelerator is very compatible with Amiga, as it uses the same processor as the Amiga 1200, and you can even lower the clock to vanilla Amiga 1200.
Price 150CAD (was 180CAD) + shipping
Additional info from icomp site:
This accelerator comes with a 68ec020 processor (guaranteed to run at 26.67MHz) and 16MBytes physical memory. 11.2MBytes of this physical memory can be used as fastmem, and 1 MByte is reserved for a fast copy of the Kickstart ROM. The CPU speed can be switched in four steps between 14MHz and 40MHz. Overclocking the card beyond 26.67MHz will require active cooling and a very good power supply; operation at this high speed is not guaranteed.
The ACA1221lc features our IDE speeder technology that accelerates reading from the internal IDE port. Other than competing products, this IDE speeder does not require opening the computer or even removing chips from their socket. The IDE speedup to PIO mode 3 is activated with a software setting and reaches a raw data transfer rate of 10.2 MBytes per second, which results in every-day performance of 3.6MBytes/s with fast CF cards. Fast harddrives with cache may exceed 7MBytes/s performance. The IDE speeder feature is not available if connected to an ACA500 or ACA500plus.
The ACA1221lc is prepared for use with our forthcoming ACA2000, where it will provide up to 11.9MBytes of fastmem. More memory configurations allow for using Zorro cards without conflicts.
Edit: new price 150CAD
Edit: package posted
