Sold ACA500+ (ACA500 plus) with X-Surf 500, cased in plexilaser.de case
  • Thread starter Thread starter nine
  • Replies Replies 7
  • Views Views 2466
nine
Somerset
Hello Amibay.
I'm selling my ACA500+ with X-Surf 500. It's cased in a laser-cut acrylic case from plexilaser.de, with an RJ45 extension leading to the back of the case for easy access for plugging/unplugging. The case is height matched perfectly for sitting alongside the Amiga 500. See photos for details.
There is a small (~2cm) scratch by a top rear screw of the case only (not the board itself) owing to my stupid fingers whilst reassembling after adding the X-Surf 500 board. In most lights, you won't notice it, but I should note it.
It's perfectly stable at all CPU speeds. In flash memory, it has patched AmigaOS 3.1 and install disks, plus 1.3 ROMs (maybe some others, I never used the preinstalled ROMs that much). There's also the install disk for the X-Surf network installation, containing a licensed AmiTCP and necessary drivers. Dual front panel compact flash, the aux port being removable so you can exchange data with another computer without rebooting. Access speed is fast, too.
It's not that old - the ACA500+ was purchased in November last year and the X-Surf 500 around January/February this year.
It's not had much use; not long after I bought it, I bought a Checkmate A1500 case with Zorro II board, and it's sadly not compatible with that adapter board.
It'll be supplied assembled but the boxes for the ACA500 and X-Surf are supplied (or I can omit if they influence the cost of shipping). The panels for removing the X-Surf board are also supplied if you want to remove it.
I'll throw in a compactflash to microSD converter as well. I've only used it with a single SD card. I note that this adapter works _fine_ with the ACA500+ but was not happy on a TF536 so it's best used with this expansion only.
I'm looking for £180 GBP excluding shipping (to be paid by the buyer, though I am flexible as to what shipping method is used).
Pictures provided below, including a customary hand-written piece of paper identifying myself as this is my first sale.
[TABLE="width: 800"]
[TR]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[/TR]
[TR]
[TD]
[/TD]
[TD]
[/TD]
[TD]
[/TD]
[/TR]
[TR]
[TD]
[/TD]
[TD]
[/TD]
[TD][/TD]
[/TR]
[/TABLE]
Update: Has been tested to work stably at 42MHz with AIBB 6.5 for a little over an hour using test module mode. I would strongly recommend a heatsink for prolonged use; I have been running it at 28MHz so have not fitted one.
Interested, depends on stability tests and shipping costs. Sending PM
No more replies from seller on private messages.
bought ACA500plus and X-Surf500 directly from iComp now.
so this is still available for anyone else interested.
Apologies for not replying sooner; I've had family difficulty and should have replied to private messages.
Confirmed card is still for sale.
