Processor / Speed
AMD Turion™ X2 dual-core mobile technology RM-70/RM-72/RM-74 (1 MB L2 cache, 2/2.10/2.20 GHz, DDR2 800 MHz, 35 W), supporting AMD HyperTransport™ 3.0 technology
Core Logic Chipset
AMD M780G Chipset.
System Bus Speed
667 MHz.
RAM / Max RAM
3 GB of DDR2 667 MHz memory, upgradable to 4 GB
Video Subsystem
ATI Radeon™ HD 3200 Graphics with up to 2048 MB of HyperMemory™ (256 MB of dedicated system memory, up to 1792 MB of shared system memory), supporting Unified Video Decoder (UVD), OpenEXR High Dynamic-Range (HDR) technology, Shader Model 4.0, Microsoft® DirectX® 10.0.
LCD Properties
Display 15.6" HD1366 x 768 pixel resolution, high-brightness (220-nit) Acer CineCrystal™ TFT LCD, supporting simultaneous multi-window viewing via Acer GridVista™ with 16:9 aspect ratio and 8 ms high-def response time.
Hard Disk Drive
320 GB SATA
Optical Drive
8X DVD-Super Multi double-layer.
Battery, Primary
48.8 W 4400 mAh 6-cell Li-ion battery pack.
3.0-hour battery life.
2.5-hour rapid charge system-off.
3.5-hour charge-in-use.
Sound Subsystem
Two built-in Acer 3DSonic stereo speakers.
High-definition audio support.
MS-Sound compatible.
Built-in microphone.
Pointing Device
Touchpad
Peripheral Subsystem
Integrated Acer Crystal Eye webcam.
5-in-1 card reader (SD™, MMC, MS, MS PRO, xD).
Three USB 2.0 ports.
External display (VGA) port.
Headphone/speaker/line-out jack.
Microphone-in jack.
Ethernet (RJ-45) port.
Modem (RJ-11) port.
Modem
56K ITU V.92 PPT approved, Wake-on-Ring ready
Ethernet
Acer InviLink™ 802.11b/g Wi-Fi CERTIFIED® network connection, supporting Acer SignalUp™ wireless technology.
Gigabit Ethernet, Wake-on-LAN ready.
Dimensions / Weight
15.1 x 9.9 x 0.6/1.5 inches.
5.94 lbs. with 6-cell battery pack.
AC Power
100-240V AC AutoSensing Adapter
Right touchpad button is a bit iffy so an optical mouse will also be supplied
Also comes with laptop bag and charger
Windows 7 30 day trial installed for demonstration purposes only.
Pictures to follow ...
£200 plus UK Delivery - Near offers are invited via PM
Core Logic Chipset
AMD M780G Chipset.
System Bus Speed
667 MHz.
RAM / Max RAM
Video Subsystem
LCD Properties
Hard Disk Drive
320 GB SATA
Optical Drive
Battery, Primary
Sound Subsystem
Pointing Device
Touchpad
Microphone-in jack.
Modem (RJ-11) port.
Modem
Ethernet
Dimensions / Weight
AC Power
