I'm hoping to find a 2mb Agnus chip for a ReAmiga 3000 build.
I'm not entirely sure which version we be appopriate but found this chart.
I'm guessin it may be best to go for a 8372AB given the comment "An equivalent VBB chip can be used to replace an 8372A or 8372B, however the PAL/NTSC select pin needs to be left floating, and a 0.1 uF capacitor to ground needs to be installed."
| Unofficial name | Chip No. | Part No. | Memory size | Chipset | Video system | Amiga models | Package | Note |
| Obese Agnus | 8372AB | 318069-03 | 2MB | ECS | Switchable | A3000(T) | PLCC | May sometimes have -039 suffix. |
| Obese Agnus | 8372B | 318069-03 | 2MB | ECS | Switchable | A3000(T) | PLCC | Same chip as the 8372AB. May also be labelled as '8375B'. |
| Obese Agnus | 318069-18 | 2MB | ECS | PAL default | A3000(T) | PLCC | Replaces 318069-03. VBB modification required. |
[td width="68px"]
8375
[/td]I'm guessin it may be best to go for a 8372AB given the comment "An equivalent VBB chip can be used to replace an 8372A or 8372B, however the PAL/NTSC select pin needs to be left floating, and a 0.1 uF capacitor to ground needs to be installed."
