OK, so I have a few remainder Alfaram A1200 cards. (http://amiga.resource.cx/exp/alfaram1200) They have been tested but all suffer from the same problem: when jumpered to enable the ZIP RAM, the A1200 won't boot (black screen). When the ZIP RAM is disabled, they boot fine and the 1M on-board RAM is visible and working fine. Strangely the cards also work when the ZIP RAM is enabled but J6 is set to NON-test mode, but only 1MB is visible still.
Now I'm pretty sure this has something to do with the PAL chips that I suspect drive the RAM logic, because I had one last card fully working and I took the PAL chips and moved to another card which started working. However when I tried to change the chips one-by-one to find out which one was faulty somehow the last set of working chips became faulty, so none of the cards work at the moment (above the 1MB that is)
I actually have new PAL replacement chips for this card specifically, they are marked U5, U8 and U9, but when I try to replace them the symptoms are the same (no visible ZIP RAM).
I wonder if someone could enlighten me:
- Could it be that mixing good and faulty PAL ICs somehow corrupts the good chips?
- Do these new PAL chips need flashing/programing somehow, i.e. is it possible that I have blank PAL chips, and I need to load the ROM on them before placing it into the RAM card? How could this be done?
- Can anyone guess which PAL chips do what? I have replacement chips for U5 U8 and U9 but not for U6 and U7.
- Perhaps there is some kind of mode where the PAL chips "learn" how much RAM is in the card?
Hi-res photos included, and here are jumper details according to the manual:
J1: enables/disables the RTC
J2: N/A
J3: enables/disables ZIP RAM
J4: enables/disables on-board 1MB
J5: switches between 4MB and 8MB ZIP RAMs installed
J6: enables/disables ZIP RAM test mode
I'm on completely unknown territory here so please forgive me if some of my questions are silly. Any advice would be much appreciated, as I would love to get these last 4 cards working. Any other advice apart from the questions above are also much welcomed.
J2: N/A
