Closed AMD Radeon RX Vega 64 Air Boost 8GB
  • Thread starter Thread starter uigiflip
  • Views Views 520
uigiflip
Nottingham
£300 including special delivery by 8pm if still lockdown by 1pm normal times within uk
[h=3]THE FEATURES OF THE AMD RADEON RX VEGA 64:[/h]
  • Brand new Vega architecture
  • Huge 8 GB HBM2-VRAM
  • 64 Next-Gen Compute Units (NCUs; 4.096 Shader)
  • Base Clock: 1.247 MHz
  • Boost Clock: 1.546 MHz
  • High Bandwidth Cache Controller (HBCC)
  • Rapid Packed Math (RPM) on NCUs
  • New Programmable Geometry Pipeline
  • Enhanced Pixel Engine
  • Air-cooled with radial-style fan
Technical Details:
  • Dimensions: 283 x 40 x 127 mm (W × H × D)
  • Slot Height: 2-Slot
  • GPU: AMD Radeon Vega
    Manufacturing Process: 14 nm
    GPU Frequency: 1.247 MHz
    Gaming Mode (Boost): 1.546 MHz
    Shader Units: 4.096
  • VRAM: 8.192 MB
    Memory Frequency: 945 MHz
    Type: High Bandwidth Generation 2 Memory (HBM2)
    Memory Bus Bandwidth: 2.048 Bit
    Memory Throughput: approx. 484 GB/s
  • Slot Type: PCIe x16 (PCIe / PCIe 2.x / PCIe 3.0)
  • Ports:
    3x DisplayPort 1.4 HBR3/HDR Ready
    1x HDMI
  • Typical Power Usage Under Load: 295 Watt
  • Power Supply Connectors: 2x 8-Pin PCIe
    Recommended Power Supply: min. 750 Watt
  • Features: OpenCL 2.0, OpenGL 4.5, Vulkan API, AMD Eyefinity Technology, AMD PowerTune Technology, AMD FreeSync Technology Support, AMD XConnect Technology
