Amiga 1000 plus replica
telonio
Athens
Ok this might sound really strange, but I am about to make a A1000 plus front cover replica from abs or plexiglass. I have design the front cover with Illustrator, but I can't tell what is the height of the prototype 1000 plus for sure. I guess it shouldn't be the same height like the 1000. The width could be different than 1000?
I doubt if anyone has this prototype. So can you possibly think what would be the measurements for this lovely prototype?
salaxi54
Incoming ASROC!
GREECE
Athens
If i were you, my only concern would be the height. Other than that, it resembles the A3400 machine. In which case, fascia width should be exactly like the A4000..
Merlin
Manchester
@ Telonio
The only base reference that you have for the size of that cover is the slot for a floppy disk. If you assume that it's the same width as the floppy disk slot in any other Amiga, then you should be able to scale the rest up of the dimensions from that.
Justin
@ Telonio
wut he said ^^^^^
the width of the floppy slot will be the size you need to work out everything else :)
salaxi54
Incoming ASROC!
GREECE
Athens
Fellas, i see no reason to make life harder than it already is. Yes, of course, the floppy slot is deffinitely a reference base, but if you take a look here, i believe that you'll agree that half the fascia is already the same...
Ok, pics are not in identical scale, but you get my point.
roy_bates
resistance is futile!
england
birmingham
im pretty sure there are a few a1000 owners here capable of supplying you with any measurement on the case you need.height width depth etc and any other measurement...
thats what i would do anyway.:)
telonio
Athens
OMG, that looks amazing - do you have any info on it?
No I don't know much about it. Only that it had the 68020 cpu and that the price should be lower than the 1000 model. It was one of the Commodore's prototypes.
Lovely slim design though.
