I'm reluctantly selling my Amiga 1000 with 256K expansion, keyboard, tank mouse and spare 240v PSU. Just not using it so might as well go to someone who will enjoy it!
It was originally NTSC but I've converted it to PAL: UK PSU, PAL Agnus and 28.375mhz oscillator installed.
Working fine but cosmetically a little grubby, though intact.
The keyboard has one faulty '3' switch (but keypad one works), a slightly dodgy '9' (intermittent) and some 'sticky' keys 'ESC', 'F4', 'Del' and 'G' due to the usual broken stem issue. I had intended to replace the switches but simply never got around to it. I'll include 6 new switches so you can fix if you wish.
I've had it on for about 3 hours tonight whilst testing and taking pictures and has been working fine.
Tested the following were OK:
Issues:
Notes:
Looking for £650, offers considered. £50 reduction if spare PSU not required.
Pickup only from Hertfordshire, UK.
I have a short video of Bubble Bobble running, not sure if I can attach it here, just ask if interested.
Edits: Additional pictures attached
- Internal drive. Boots from a Kickstart disk then into Workbench. Tried loading a couple of games and utilities, no problems.
- Composite video port output
- RGB output
- Stereo sound output
- External drive
- Game/mouse ports
- Keyboard (apart from issues mentioned above)
Mouse
Issues:
- The PSU fan sounds a little 'clonky'. Works fine but I will include a new spare if wanted.
- Case is a little grubby and marked
- Sticky feet missing
Notes:
- Printer and Parallel ports were not tested.
- Pictured external drive not included, was just used for testing.
- I can't find the original Kickstart or Workbench disks, tested with working copies that I cannot supply.
