Amiga 1200 And ZZ9000 Tower setup
  • Thread starter Thread starter amigat
  • Views Views 415
amigat
Amiga 1200T Cool
Penarth,Wales
Here I have another Amiga 1200 Tower setup with Micronik 5.44 Busboard, which I have modified with my own video enabler and left and right audio signal which is not connected on this Busboard and ZZ9000 RTG Card.
Here Is Micronik 5.44 Busboard
Here Is ZZ9000 With Audio board
Here is my tower setup with following cards
ZZ9000 with Audio Card
A-EON Megamix audio card
X-Surf-100 with USB module
Petsoff Dalfina Lite sound card
Pin sharp HDMI output from ZZ9000 Scandoubler
Amiga Hard drive booting into workbench, No screen flicker and pin sharp
Workbench booted, screen is in 1280 x 1024 16 bit, very clear screen with ZZ9000
I have done a small video of it booting, There is a slit issue with ZZ9000 and Busboard,
Issues are following
1, USB don't work, Poseidon v4 sees the USB and active the board but not able to config it.
2, network on the ZZ9000 also don't work either
it could be software error and I will reinstall OS3.9 Again and do fresh install of everything to see if makes any difference.
Also ZZ9000 seems to be having screen refresh issues, when I do reboot and Amiga activate ZZ9000 And switch to RTG mode screen will display screen before reboot, but whenl Iprefs to called the screen is refreshed and all working fine from there.
I will try do more videos to show you what I mean.
Another video added, No issues with screen not refreshing after reboot with OS3.2.2, so it must have been OS3.9 Issue!
