Closed Amiga 1200 power tower with Blizzard PPC and Mediator + lots of cool hardware
  • Thread starter Thread starter amigat
  • Replies Replies 2
  • Views Views 1128
amigat
Amiga 1200T Cool
Penarth,Wales
Hi All
Here is for sale Amiga 1200 Blizzard PPC tower setup with Mediator TX Black bus board.
Power Tower case with 2 x 12 cm blue led cooling fans.
Commodore Motherboard rev 1.d.4 Recapped.
kick start 3.1 ,3.1.4, 1.3 and diag rom v1.2 all in a multi kick switch adaptor (just flick the switch on front of tower to select which ROM you want)
Not real kick ROM's but images of Kick starts into memory chips in kick start sockets.
Indivision AGA MK2 CR connected to Rattle monitor switch.
Rattle monitor switch with drives on floppy disk connected internally to parallel port for power and switch control.
elbox keyboard adaptor.
Blizzard PPC 68060 with FPU and MMU at 50 MHZ and PPC at 330 MHZ no SCSI with cooling fans on both CPU's
Mediator TX Black bus board latest version with PCI cards.
PCI Voodoo 3 3000 with cooling fan on heat sink (been repaired by me due to 2x damage traces fully working now)
voodoo video output is connected to Rattle monitor switch (internally)
PCI sound blaster (audio connected to CD Rom's)
PCI TV card
PCI network card
PCI usb Card (spider) with Cdrom disc
Mediator manual and drivers on CD ROM disc.
2 x IDE DVD ROM's drives
IDE Hard drive (Maxtor) 10 GB Blank Drive.
cooling Fan controller for cpu's and case fans.
Amiga kit IDE adaptor with Adaptor fitted of Gayle Chip (drives on floppy disk)
ATX power supply (230v) with power cord.
880k floppy drives (some times it can't read disk)
with turbo switch on front of case if orange led is light up then rattle monitor switch is on RGB output and auto select of video signal when drivers installed, but if led is not light up via press turbo switch then rattle monitor switches to RTG output (voodoo) I set this up this way due to OS4.1 don't working with drivers for rattle monitor switch. so i can select which output i want to view.
It also comes with mouse.
PS2 to dim cable for keyboard (no keyboard included)
OS4.1 cdrom
OS3.1.4 Floppy disk.
Drives for indivision MK2 CR (copy all disk to ram then install from there)
OS3.9 boot disk only for A1200 setup.
and other drives on floppys too.
This is pick only Due too heavy and expensive equipment to post (sorry)
I live In (Barry near Cardiff)
Asking was £3000 + PayPal now £2500 + Paypal fees
Also on sale else where
