I have an Amiga 3000 that has some battery damage. The previous owner did not remove the battery until it was too late. It works ok until I go to use the built in flicker fixer port. When that is connected there is ghosting/garbage in the display. I would also like it recapped while it is being worked on. Is there anyone in the US that does this type of work? I would not have a problem sending it overseas, but it would be better if it was done in the US for obvious reasons.
Thanks!
Thanks!
