amiga 3000 motherboard revision 8.9
  • Thread starter Thread starter baz
  • Replies Replies 11
  • Views Views 267
baz
england
merseyside
Hi
I have an amiga 3000 that works fine with the built in 030 cpu but when i use the 040 card and change the jumpers to external it wont boot why?
Any ideas please
Hello,
is the same board that i have managed? What 040 card is yours?
Regards
Stefano
Hi Baz, is the 040 Rev 3.1 or higher? There's a few issues with Rev3.0 and the A3k, mine wont boot with the Rev 3.0 in (solid grey screen) but runs like a charm with both my 3.1 and 3.2 in.
Hi m8
3.1 gal chip 0-3 which i think is upgraded
It says Static Column Fast-RAM on the big book hardware web site that it can cause the 3000 not to boot which fastram is that?
Only 2 Jumpers are set to EXT, J100 and J104. J102 is set to INT. ;)
Will check that out and test the 3000
nothing happened
Ok, which version Kickstart ROMs are installed? (The old v1.4 ROMs don't support an 040 card).
Next, check J851 (Ramsey CLK speed jumper). You could pull the first bank of Fast RAM (but I doubt it's the problem here).
Also, what is the A3640 clock speed?
Ramsey clock set at 25m
its a overclocked a3640 running at 32 mhz
roms 3.1
I'd be trying it with the 3640 at stock first to rule that out.
Thanks guys got it working after changing the crystal to stock on the 3640 card
