Amiga 4000: Audio issues
AndyLandy
Acceleration!
Treasurer
Southampton
I've just acquired an A4000 from a friend and I'm planning on giving it a 'once-over' and bring it up-to-spec a little before he reclaims it. For the most part, it's in good working order, but there's an unusual quirk with the audio. Both sockets on the back are outputting the same channel (not worked out which one, yet) so -- anyone know what causes this and more-importantly, have any suggestions to fix it? Is this is well-known 'A4000 SMD capacitor / Audio' problem, or is this something completely different?
davideo
I look like Gizmo
Staff member
Administrator
Staff Moderator
Treasurer
Boston, Lincs
The 4000 will shove out the same sound on both channels if only one audio plug is plugged in.
Have you got another set of leads to try - just in case?
Dave G :cool:
Zetr0
Ya' Like it Retr0?
Hiyas Andy,
the A4000 Audio port is notorious for faults
its likely you have a sound doplar caused buy bad filtering of from the caps (i.e. bad caps).
heres a schematic it looks a little busy but its quite easy to follow, also have a look at this thread on EAB might help too.
AndyLandy
Acceleration!
Treasurer
Southampton
Dave G :cool:
Good suggestion, but alas, it's not the leads. I've tried three or four different sets and know that these leads/speakers work fine on other Amigas.
The odd thing is that both outputs on the A4000 are the same audio channel. I've tried plugging only one in, tried swapping them round, tried using a 2->1 cable, all to no avail. The other audio channel just isn't there.
davideo
I look like Gizmo
Staff member
Administrator
Staff Moderator
Treasurer
Boston, Lincs
Sounds (pun intended) like it's definately a caps problem then (n)
Dave G :cool:
AndyLandy
Acceleration!
Treasurer
Southampton
Hiyas Andy,
I suspected it'd come down to shonky SMD caps... Looks like more soldering is going to be required.
psodas
Athens
Hi. Have you try to connect the CD out to the cd audio connector? If yes, the 2 chanels is again in trouble? Both in one? If no your problem is before and you must check U402 LF347 type. If yes your problem is after, possibly U403 LM833 type. In all cases you MUST change the capacitors.
Sorry for that, but I believe n any case cause capacitors is not your only problem.:(
Just don't use tantalum capacitors for the audio section (nor for power filtering, you'll be warned!) and all will be fine.
Ordinary electrolytic capacitors is all you need for the audio section, even the 85°C ones will be enough. Remember they need to be 35V or higher.
AndyLandy
Acceleration!
Treasurer
Southampton
So, my friend and I have had a chance to take a look at this. It would appear the U402 OpAmp is looking quite minging as one or two of the capacitors around it have defecated their mess on to the board.
So, there are definitely a couple of SMD caps that could do with some love. Do you guys reckon it's worth replacing the OpAmp as well?
Also, how is it best to clean up the electrolytic detritus that's befouled the precious Amiga components? Lemon juice again, or something different?
Zetr0
Ya' Like it Retr0?
@Andy
I would change the OPAmp as well - reason being that you will have to remove it to get at the electrolyte that is underneath it - slowly corroding the board -
Remove the U402 - and since you are at it the U403 as well - clean up with a little acetic acid and clean completely... allow to dry then install new caps and components.
its the only way to be sure.
abraXXious
Had the same problem, except I also had distortion on the output. Had the caps replaced and added a larger PSU (550 watt) and problem was gone.
The reason I replaced the psu was I am running heaps of gear in that a4k and I read online that when the 12 volt line is over taxed then one of the first things to play up is the audio.
Also, what is contact cleaner like for cleaning off electolyte leakage? Its quite expensive but VERY convenient and rips tarnish etc of corroded contactors etc quick smart.
Any thoughts?
Harrison
West Sussex
I always just use carburettor cleaner and some cotton buds.
AndyLandy
Acceleration!
Treasurer
Southampton
I'll bear that in mind, although this particular A4000 isn't going to be chock-full of exciting things. My friend doesn't have the cash or the inclination to rack it full of cool things.
My plan is to get it all repaired, do the lithium battery hack on it, upgrade the Kickstart ROMs to 3.1 and put a CF/IDE hard disk and IDE CD-ROM in it. He might also consider a Zorro network card for it, but we'll have to wait and see on that.
@Harrison: Thanks for the tip, if you reckon carburetor cleaner is good, I might have to make a trip to Halfords and pick some up. :)
