The crash only occured when the Amiga 1438S monitor is connect to the Amiga 4000 while the monitor has not been turned on.
If I don't turn the monitor on then it crashes in a loop.
I thought it is only my Amiga 4000 setup, but years ago I saw another user on a Commodore Meeting has the same problem.
Does someone know why this problem occured?
If use a adapter from rgb adapter to vga adapter and then connect to VGA to RGB adapter and Monitor, then this problem will not occur.
