As the title says, A4000D case is generally in good condition. Front is a little off white but not much, I photo'd it on a pure white surface to give an idea of what to expect. The hard drive brackets are not originals a member on the board made them up for me (massive thanks to NeutronUK). The PSU works but it's very noisy, the long rod that switches it on and off doesn't stay attached as the lug snapped off the psu side. It does however stay in and works fine if you press it gently without force. Don't know what else there is to say, everything you need is here, the inside base of the case looks a bit manky but it's the plastic sheet that has discoloured.
Asking price is £140 plus postage. I also have a 68030EC25 CPU board I could sell but only with the case for an additional £25.
