Closed Amiga 500+ KS 2.04 working base unit
  • Thread starter Thread starter sputnik
  • Views Views 1007
sputnik
Barnsley, Yorkshire
£30 + Post (+fees, or Paypal "gift", or UK Bank Transfer) - PP £6.50 UK
Fully working A500+ Base Unit Rev 8A, Kickstart 2.04 37.175 (no mouse or power supply - base unit only)
Battery was removed a long time ago and lacquered (i.e. clear nail varnish :-) ) There is some discolouration around the solder mask on that area, but it had not eaten anything, and has worked fine for years. As you can see the rest of the board looks great, no leaking caps or other nastiness.
Tested ports : RGB, Mouse, Joystick, Stereo L / R all working 100%
Not tested : serial, parallel, ext floppy, composite
Floppy drive works (a bit audible like most of these old Chinons are by now.)
Keys / LEDs work
Internal expansion connector works, no bent pins
Yellowed as can be seen with various wear from usage but overall complete.
20140715_131829.jpg20140715_005448.jpg20140715_005501.jpg20140715_131632.jpg20140715_131639.jpg20140715_132003.jpg
