Amiga 600 CF Hdd question
owen2471
england
Sandwell
Hello. I have just installed a 4 gb CF hdd in my Amiga 600. Only problem is I am not on kickstart 37.300 which the hdd needs to boot.
Any help gratefully received
davideo
I look like Gizmo
Staff member
Administrator
Staff Moderator
Treasurer
Boston, Lincs
They're cheap enough to buy which may be your only answer
IAmAddicted
Germany
Kurpfalz
Nearly every Amiga Dealer has kickstarts in stock that might fill your needs.
davideo
I look like Gizmo
Staff member
Administrator
Staff Moderator
Treasurer
Boston, Lincs
Officially you'll also need a set of WB discs to install WB.
These can be found in the wild if you don't want to buy a set
SilkWorm
VA
any stock amiga A600 should boot from cf hdd . WB 2.04 is fine .
There were stock A600s with ROM 37.299 lacking the feature to boot from internal IDE.
Minimum to boot from IDE is 37.300 which was included in A600HD models.
levo-ace
ASA survivor
buckinghamshire
I have had three A600's and never had the problem , they must have been later revision's .
I still have one of the A600's and it has a 128mb DOM installed , that it quite happily boots from .
At least it is all sorted now .
