Sold Amiga 600 (computer only)
  • Thread starter Thread starter -Acid-
  • Replies Replies 14
  • Views Views 1829
-Acid-
South Shields
Tested PAL A600 for sale. All keys working fine, sound is fine, video checked on RF and composite, mouse and finally joystick ports tested. Spent an hour playing Turrican 2 on it without problems this evening. As you can see from the pictures it has the number 2 key missing but it is still fully functioning it just has the cap missing which should easily be replaceable. I have also tested the RGB, parallel and serial ports with a system analyzer and all seems good with the correct voltages reported.
Asking £30 (was £35) plus postage.
Are all the chassis plastic clips present? Also, are the plastic screw holes in good shape? Even better, is the warranty seal non-broken?
EDIT: Yes, I'm declaring interest if it's in the shape I'm asking :thumbsup:
Back clips appear to be fine, the side one by the floppy drive next to the joystick port looks either broken or not clipped together properly and the seal is broke.
It's me again, I might be interested after all. Do you happen to know what motherboard revision the A600 has? Also what's the shipping costs to Norway?
Postage to Norway is £28 (it's the same price no matter if the box weighs 5kg or 20kg I think it's just a flat rate).
4Play decided to withdraw, this is still available.
