I have for sale 4 mechanical keyboards as per this project:
These are revision 2 Pcb keyboards fully assembled including proper stabilizers. I have tested several different MX switches, so these 4 keyboards only differ in the type of the Cherry switches used. For sale is:
1x 2 x Outemu Clicky Blue (1 Sold to kavanoz, 2nd to Argo)
1 x Outemu Quick Silver (sold to sandlbn)
1 x Black Hyperglide Linear (sold to Epicox)
For more info regarding differences in switches check this video:
Keycaps are combination of the standard ISO set and blank custom sized individual keycaps (check the pictures). As per the project creator Aeberbach's comments dating few years back, the only way to get semi proper keyset is to go thru SPkeyboards.com, however you will still be missing several proper functions keys and the space key. The cost went up, so expect to pay approximately $200 USD for this set alone. Blank keys can be populated using stickers, and there any many custom options out there, so that's the only task left for you if you choose to do it.
Regarding the caps lock key, MX switches have LED bulb opening on the lower side of the switch, so I've decided not to drill any holes for the light opening. Installed amber LED glows decent enough and it is easily noticed. All 3D printed parts are done using Jessie Premium PLA Amiga Beige color.
Mounting rails are included, there is one long and 2 short parts to be glued to the PCB as per the original instructions. Hot glue gun works fine although you have to be quick to prevent premature solidifying. Word of advice, mount keyboard first inside of the upper case like you would install the original keyboard, center the keyboard and then install 2 smaller rail pieces and finally the longer rail.
Each purchase will include ISO set leftovers keycaps.
Price per keyboard is 220CAD/150 Euro/160 USD, plus PayPal and shipping fees.
