Amiga 600 Rgb Output only Blue
rayan259
Canada
Calgary
Hi
my amiga 600 rgb output only blue but component is ok and good color:-(
sound out left & right is mono test by amiga test floppy chanell 1- 2 is mute :-(
you can help me?
problem with Ic or others?
sorry for english
thx:smile:
supaduper
west midlands
Check the outputs R/G/B from the sony encoder chip (CXA1145) location is U12, if signals good then should be easy to trace fault from encoder to RGB connector.
sound problem is most probably a bad capacitor.
Your English is excellent :)
roy_bates
resistance is futile!
england
birmingham
you have a few problems,and you probably have capacitor leakage as well as maybe failed ics maybe even broken traces at worst.
but to be sure someone capable of repairing it would need to look at it close up.a picture wouldn't probably help.
rayan259
Canada
Calgary
in cannon fodder no vocals only music however both the left and right audio jack is
I thank you for your help
supaduper
west midlands
Yes there is bad oxidisation/leakage on the capacitors , do recap of the board
supaduper
west midlands
both of them the two caps behind the keyboard are the Audio ones and they have definitely leaked
