For Sale AMIGA 600 - Tested / Working - Recapped, 2D Rev. Furia 020, 3.2 OS, 3.2 Kickstart, SD Hard Drive, PCMCIA CF Card etc.
  • Thread starter Thread starter uniquefreak
  • Replies Replies 4
  • Views Views 743
uniquefreak
Derbyshire
AMIGA 600 - Full Unit - Latest 2D Motherboard - Recapped, Includes Amiga OS 3.2 Retail Copy, with Serial Number - Unopened.
8GB SD Card Hard Drive. PCMCIA adapter with Compact Flash.
£489
£399 + Postage.
(UK £18.99)
(EU £32.50)
(USA £59) - most other places outside of the EU should be around this price.
PayPal Friends and Family, or please add extra to cover Fees.
These are typically ParcelForce Global Express services, with increased insurance to cover the item value.
Weight coverage is up to 5KG. The Amiga typically weights around 4KG when packed. Tracking will be provided.
DETAILS:
Amiga 600 - 2D Recapped Motherboard, tested, fully working.
Fitted With:
3.2 Kickstart Chip
1MB New Chip Ram Trapdoor Memory Upgrade
Furia 020 Accelerator Card Rev 3, with 68882 FPU
New 8GB SD Card (as the hard drive)
New SD to IDE adapter + Plastic support bracket
New PCMCIA Compact Flash Card adapter (to transfer files between Amiga and PC)
+ 4GB CF Card.
Retail Box Copy - of Amiga OS 3.2, unopened including serial number on front cover. (if you don't have a CD drive, I can offer a digital download link, after delivery has been confirmed - you will receive the physical media and licence key in either case).
The SD Hard drive has a clean installation of 3.2 on it, ready to use. This also includes WHDLoad (please note the game shown is purely for test purposes and will be removed prior to shipping) however, WHDLoad will remain installed so you can add your own games.
The drivers to read a PC formatted Compact Flash card, are installed (screen shot shows this working and mounting the FAT32 CF card). Please note, the Furia upgrade card provides an extra 9.5MB of Fast Ram. However, this is designed as standard to disable the PCMCIA slot on the A600. If you hold down the Amiga soft-reset keys for 6 seconds and release, the Amiga will boot in PCMCIA friendly mode. The Furia will still work, but it will only provide 4MB of Fast Ram (which is still plenty for most tasks). This is by design. See screen shots showing both modes and available memory in each. The Furia vastly increases the unit's speed in all cases and the FPU further enhances performance.
The motherboard has a good clean back shield with plastic backing installed. The top case has 2 minor pimples on the bottom edge where a prior owner used the wrong screws in the bottom of the case (a common silly issue). The case is in fantastic condition apart from this. I have shown and will include a spare top case, also in great condition. If you want to swap them over.
No power supply, mouse or monitor/TV lead included. You should be able to buy these online or locally at low cost. The power supply is heavy, so it may otherwise increase the postage.
More pictures than I can attach, available here:
