Amiga and MMU equipped Accelerators
AndyLandy
Acceleration!
Treasurer
Southampton
It is the Motorola EC030 at 50MHz you got here.
No MMU, but still is a 50MHz 030!
Sorry for hijacking the thread, but what actual difference does an MMU make to an Amiga? I didn't think AmigaOS had any form of memory protection.
I guess if you wanted to run 68k Linux, you'd need one, but if you're running Workbench...?
arnljot
Dad, gamer, nerd, amigian
Oslo
Oslo
relockick, backkick and other kickstart to fastmem type tools use mmu to trap and redirect memory accessing.
AndyLandy
Acceleration!
Treasurer
Southampton
They don't require it. Relokick works for me on bog-standard 68000 Amigas. Maybe there's a performance boost if an MMU is present?
Also you need a working MMU to run OS3.5 and 3.9. Witohut one the Amiga will have to use other nasty tricks to load the ROM updates.
AndyLandy
Acceleration!
Treasurer
Southampton
Still, those nasty tricks seem to do the job. My A1200 with an EC030 runs OS 3.5 very nicely indeed. :)
Zetr0
Ya' Like it Retr0?
So what does an MMU do?
well my fellow forum chummy Alphonsus from eab states it very well -
alphonsus said:
The MMU converts one set of memory addresses to another, usually on a program by program basis.
Say program A wants 2Mb. It gets told it has addresses x to y.
The MMU can map that address range to wherever it wants to in the address space, including to hard disk (hence needing the MMU to run virtual memory properly).
Program B can also be given memory including addresses x to y, because the MMU redirects those addresses somewhere else in he address space.
Amigas never needed an MMU, but it is needed to run virtual memory, memory protection (fewer crashes) and most versions of linux.
A common thought is that the blizzard accelerators use the mmu to maprom, this is not the case - infact its the memory mapping logic that does the magic.
Toni Wilen said:
MMU was was usually only used for non-blizzard softkicking (A3000 for example required it) and debugging. Amiga virtual memory was a toy because there is no OS-level support.
So what programs actually used the MMU ?
Enforcer
Enforcer is an advanced debugging tool for Amiga computer systems equiped with a 68020/68851, 68030, 68040, or 68060 CPU.
It uses the MMU to help detect stray pointers and access to invalid memory.
Gigamem
Gigamem allows Amiga owners to use hard drive space as RAM.
Other than an MMU Gigamem requires some free hard drive space - (essentailly using this as a paged swap-file).
This means you can images and projects that are too big for your current memory setup. So instead of needing additional RAM to handle one or two projects, you can use Gigamem and used Harddisk space.
Fusion and Shape shifter emulators
These can make use of the MMU, although they are slower when using it.
Amix or NetBSD
Essentially carients of linux, as such run protected memory environments.
chiark
AmiNerd
Yorkshire
I believe there's one essential reason for having an MMU if you're a developer on the amiga, and that's Enforcer. It protects your machine (and sanity) from your own stupidity...
Gigamem is a nice idea well implemented, but is not really useful due to the speed. You need to be truly desperate to use it...
Zetr0
Ya' Like it Retr0?
Or on Fast SCSI 3 via a Cyberstorm Mk3 / Cyberstom PPC
Still i have some hope that an 060@66 with FastSCSI2 would cope nicely with Gigame.... although to be fair... trying to find a project that requires more than 128MB of Ram on an Amiga is a little hard....
Kin Hell
U.K.
Cornwall
GigaMem running on a Rev7 Oktagon SCSI card is wicked. At the time, I only had 16Mb fast on the Mobo & 8Mb on the Oktagon with an A3640 @ 33Mhz. Trying to render some scenes in Imagine 3 always ran out of memory. GigaMem allowed everything to work as normal & there was no noticeable slow down for it either.
