Closed Amiga Apollo Vampire II with IDE SD Interface and OS for A1200 for 280 euro + 40 euro for IDE I/F and SDCARD
  • Thread starter Thread starter Titan.io
  • Replies Replies 6
  • Views Views 686
Titan.io
Rating - 0%
0   0   0
Belgium
Brussels
Hi fellow Amibayers,
I recently purchased am Apollo Vampire II from maker here on AmiBay. I have decided to downgrade my A1200 as I am now the proud owner of the A3000 and it already has an accelerator. Therefore I am offering this on AmiBay for 280 euro for the Vampire and optionally another 40 on top for the SDCARD and IDE interface as seen in the picture which has the Apollo OS installed.
It's brand new since February and I have not really used it other than to set it up and install the OS, etc. I have the original packaging.
Declare interest if you would like to buy or offer.
Includes the license of the Core provided by Apollo-Team. It connects to the trapdoor expansion slot of the Amiga 1200. Powered by the Apollo Core 68080 which is 100% code compatible with Motorola 68K processors, it is currently up to four times faster than the fastest Motorola 68060.
Specifications:
• Altera Cyclone III
• Apollo 68080 equivalent to 68030 1GHz / 68040 500MHz / 68060 250MHz
• Multiple CPU configuration options (68020/68030/68040)
• 153.71 MIPS / 81.67 MFLOPS / 147255 Dhrystones with SysInfo
• 28nm technology
• 128 MB FastRAM
• SAGA Core Chipset through HDMI.
• Video modes up to 1280×720@60Hz, 1920×1080@24Hz
• Color depths of 8, 15/16, 24, 32 bits per pixel
• Hardware-accelerated video playback
Ports:
• 44-pin Fast IDE Interface (up to 14 MB/s data transfer speed)
• JTAG Socket
• Ethernet Module Connector
• Expansion Socket
• Digital Video Out (DVI)
• MicroSD Card
Certification: Vampire V4 is CE, WEEE and RoHS compliant and fast DDR3 memory.
Proof of ownership is in the attached image.
Witam wszystkich Amibayerów,
Niedawno kupiłem am Apollo Vampire II od producenta tutaj na AmiBay. Zdecydowałem się na obniżenie wersji mojego A1200, ponieważ jestem teraz dumnym posiadaczem A3000, który ma już akcelerator. Dlatego oferuję to na AmiBay za 280 euro za Vampire i opcjonalnie kolejne 40 na górze za interfejs SDCARD i IDE, jak widać na zdjęciu, z zainstalowanym systemem operacyjnym Apollo.
Jest nowy od lutego i praktycznie go nie używałem poza konfiguracją, instalacją systemu operacyjnego itp. Posiadam oryginalne opakowanie.
Zgłoś zainteresowanie, jeśli chcesz kupić lub zaoferować.
Zawiera licencję na Core dostarczoną przez Apollo-Team. Podłącza się go do gniazda rozszerzeń zapadni w Amidze 1200. Zasilany przez Apollo Core 68080, który jest w 100% kompatybilny z procesorami Motorola 68K, jest obecnie do czterech razy szybszy niż najszybsza Motorola 68060.
Dane techniczne:
• Cyklon Altera III
• Apollo 68080 odpowiednik 68030 1 GHz / 68040 500 MHz / 68060 250 MHz
• Wiele opcji konfiguracji procesora (68020/68030/68040)
• 153,71 MIPS / 81,67 MFLOPS / 147255 Dhrystones z SysInfo
• Technologia 28 nm
• 128 MB FastRAM
• Chipset SAGA Core przez HDMI.
• Tryby wideo do 1280×720 przy 60 Hz, 1920×1080 przy 24 Hz
• Głębia kolorów 8, 15/16, 24, 32 bitów na piksel
• Odtwarzanie wideo z akceleracją sprzętową
Porty:
• 44-pinowy interfejs Fast IDE (szybkość przesyłania danych do 14 MB/s)
• Gniazdo JTAG
• Złącze modułu Ethernet
• Gniazdo rozszerzeń
• Cyfrowe wyjście wideo (DVI)
• Karta micro sd
Certyfikacja: Vampire V4 jest zgodna z CE, WEEE i RoHS oraz posiada szybką pamięć DDR3.
Dowód własności znajduje się na załączonym obrazku.
Bardzo proszę o link do ogłoszeń, gdzie można kupić Vampire v2 za 280 euro, dziękuję i pozdrawiam
If you are interested to buy mine then you can click on "declare interest" is how it works here (I am quite new myself as a member).
I don't seem to see it on my post here, perhaps it;s becauseI am selling it. In any case if you would like to buy then yes for 280 euro it is yours. Let me know and I can message you directly on Amibay.
@Titan.io please note. Any bundled software or OS must include the original licence and disks/disc, otherwise you will need to wipe the SD Card.
