Amiga Bootselector / Floppy Switcher DF0/DF1
Compatible with Amiga 500/500+/2000. It allows you to switch DF0/DF1, making it possible to boot from either a Gotek drive/external drive or the internal floppy drive.
Kickstart 1.3 does boot from DF1. With Kickstart 2.x/3.x you can start from an external unit (DF1), but in both cases the most of the games will boot only if the floppy drive is inserted in DF0, no matter whether you have Kickstart 2.x/3.x or not. This DF0 selector solves this issue. It works on any Amiga 500/500+/2000 regardless of the Kickstart version.
And it is also compatible with floppy disk drive emulators as the Gotek or the HxC or original Amiga external floppy drive
Please note that is equipped with machined pin gold plated
How to install:
PRICE --> 19€ + shipping
How to install:
- Switch off your Amiga.
- Remove the Even CIA chip
- Put boot selector into socket
- Put chip on top of the boot selector
- Connect switch on/off to boot selector (not included but I can do it)
