Amiga CD32 and TF330 wont boot games from CD
  • Thread starter Thread starter micielk
  • Replies Replies 3
  • Views Views 321
micielk
Poland
Lodz
Hello
I bought TF330 recently and I got some problem with it,
I have installed TF330, when try to put game on Cd and reset to boot game instantly, game mostly wont boot but sometimes shows a start screen of game, and that all, CD is spinning but everything freeze
When I boot CD32 without CD workbench starts
If I remove TF330, CD game boot without problem
I tought that I need to recapped it and I did, also added ATX power supply, thought that laser doesent have enough power, but problem is still the same
Should I boot CD game from workbench? I didnt test it that because i dont have mouse right now or maybe TF330 is faulty?
Anyone help please?
Have you tried removing the Disable Jumper that is next to the TF330 IDE port ? as that might work , it all depends also if you have the latest firmware as early TF330 firmwares had the `Disable` bug, so even if you remove the Jumper it still will not work
This was done in Firmware Rev3, so to check if you have the latest firmware hold the the two mouse buttons down on booting up the CD32 and this will give you the early startup menu, click on `Expansion Board` and see what `Product` number is ..should be 3
Also remember some CD32 disks will not work with `Fastram` thats why there is a `disable` jumper
Hello
Sorry for late response I was away for few days, I checked I got product number 3, I tried to remove jumper and all I got was green screen after couple of seconds, Is my TF330 faulty? or should I update firmware?
actually thinking about it Removing the jumper will not work as there is still a bug . it does not disable the TF330
you can always try reflashing it to see if it improves the setup
