Amiga HD drives
RedDaemonFox
Amiga's enemy is my enemy!
United States of Hell
Melbourne, FL 32901
Ive heard amiga HD drives work different from a PC HD drive, not just in filesystems, but in the way they write. For instance, if you got a catweasel and used your PC HD drive to write a HD image onto a floppy, the contents end in garbage. The same goes for a HD Amiga drive in a PC. So, what's the biggest difference, and do you think it would be possible to modify/hack a PC HD drive, creating millions of cheap amiga drives, that can write to an OFS floppy?
Justin
Re: Amiga HD drives
i know that PC HD floppies work in a completely different way to miggy ones, something to do with not being able to run the PC drives slow enough. i'm sure the Gurus on here will be able to explain it better
cheers, JuvUK
Re: Amiga HD drives
OK, I wait a bit to see if someone post first... :whistle:
The Amiga drives normally use the same bit rate when read/write, and for that when in HD mode the rotation speed must be halved to 150rpm.
Some other hardware converters use some additional logic to use a normal 300rpm HD drive (Amtrade A357, Promigos A500/A1000 HD floppy, kylwalda + Catweasel, Power Computing's XL drive, among others...
Zetr0
Ya' Like it Retr0?
Re: Amiga HD drives
@Juvvy
you have been hanging around me to long m8y LOL
Justin
Re: Amiga HD drives
Zetr0 said:
@Juvvy
lol nah, how could i hang around a top bloke like you for too long? surely that's not possible! :grouphug:
