amiga minimig with Philips CM8833-II?
Amiga Forever
Yorkshire
I need cable for amiga minimig connected to Philips CM8833-II and will I be able to get it from Amigakit if they sell them?
mjnurney
we live as we dream. Alone.
england
Milton Keynes
The minimill is VGA 31 kHz not 15 kHz as the old Commodore stuff is so a lead won't be possible , the minimig uses a standard VGA PC output.
You could possibly convert VGA to composite / s video and then use composite or s video mod on the phillips but its not easy.
unless I'm mistaken...
scrappysphinx
Confused retro man
Nottingham
The minimig has a jumper on the board to select 15/31khz so it might be possible
BLTCON0
Math inside
Hellas (Greece)
Chania, Crete
Well, they do make a minimig-to-SCART cable so I guess they can craft one for your monitor as well. If I'm not mistaken the CM8833-II uses a standard DB9 connector for RGB input.
Ask them and find out.
deladrevoc
Hampshire
Used together with this...
http://www.retrocomputershack.com/PDF/Philips CM8833-II Scart Apaptor MK3.pdf
Amiga Forever
Yorkshire
Thanks but does he sell them as it seem that he doesnt have it :(
I going send him email to if he had stock in them :)
Amiga Forever
Yorkshire
Philips CM8833-II doesnt have scart :( unless I get Scart adapter MK 3
deladrevoc
Hampshire
Those cables give it SCART, they are SCART sockets not plugs. They are essentially the same product as the MK 3, they just use less materials to manufacture. You would also need the Minimig SCART lead from Amigakit
Amiga Forever
Yorkshire
I had good look at the picture again of new design and my scart(the one I go from Amigakit) to connected to new design(from ebay) and it will work :)
Thank you so much for help deladrevoc (y)
P.S. Just bought new Design :D
deladrevoc
Hampshire
You're welcome, hope it all works - can't see any reason why it wouldn't :)
I take it you sorted out the firmware/software issues you were having with the Minimig in the end?
