Amiga Mouse
mikefr24
Michigan
Are all the different mice that came with the different Amiga computers interchangeable? For example: Will my A500 mouse fit an A1200?
Mike
The mouse of all wedge and big box Amigas are interchangeable.
So one from A500 will fit and work flawlessly in one A4000T, for example. And vice-versa.
The original from A1000 is exclusive because of the L shape of the connector. All mice fit in it if no side expansion devices are used (they will block the mouse port, so only the L-shaped will fit).
CDTV & CD32 are different beasties: they use a kind of "serial" Amiga mouse.
Templar
Hellas
Cydonia
CDTV is different, it uses a PS/2 type of mouse, although it's not the same as the standard pc mouses.
CD32 uses the same mouse as all Amigas.
You are right, mate. I simply forgot about CD32 having the normal 9pin D-Sub connector as other Amigas.
