For Sale Amiga scandoubler for all Amiga computers: APOLLO X / APOLLO XS / APOLLO XC
  • Thread starter Thread starter axel81
  • Replies Replies 116
  • Views Views 13455
axel81
Italia
Monza Brianza
(VGA Upscaler for your AMIGA!)
apolloXC.png222.jpg s-l1600 (2).png s-l1600 (3).png s-l1600 (4).png s-l1600 (5).png 20230428_182230 (FILEminimizer).jpg 20230428_182802 (FILEminimizer).jpg 20230428_183110 (FILEminimizer).jpg
@VIDEO (MP4)
APOLLO X on A600...Startup Workbench (1920x1200@60Hz)
View attachment 20230429-083333_compressed.mp4
@VIDEO (MP4)
APOLLO X on A600...Chuck Rock game (1920x1200@60Hz)
View attachment 20230429-083537_compressed).mp4
@VIDEO "SCROLLING TEST" (MP4)
APOLLO X on A500...Sensible Soccer 96/97 game (1920x1200@60Hz)
View attachment 20230430-113458_compressed.mp4
What better thing to finally connect your Commodore AMIGA to any monitor/TV with VGA input?Now with APOLLO series it is possible!
APOLLO series guarantees the VGA connection of your AMIGA to a monitor/TV with VGA input with the best video quality: video resolution capability up to 1920 x 1200!
Forget the poor performance of the GBS8200 converter (colors/missing pixels/low resolution..only up to 1360 x768!)
and other OSSC scandoubler
KEYS FUNCYION:
RESET
If a resolution that is too high and incompatible with your monitor/TV is chosen, simply press this key to auto-configure APOLLO on the first resolution supported by your monitor/TV
SCREEN RESOLUTION
With this button you can choose the video resolution you prefer..up to 1920x1200!
VIDEO FILTER
With this button you can choose the video filter that we have stored on APOLLO..choose what you prefer.
APOLLO X - Compatibility & Features (150€ + shipping)
  • Compatible with ALL AMIGA COMPUTERS !
  • APOLLO X has a DB23F to be connected to the RGB video output of the Commodore AMIGA and a female DB15 HD panel connector to which you will have to connect the VGA cable to go to the monitor/TV (VGA cable not included). For the audio connection just connect your cable (2xRCA-jack) to your TV/monitor input (audio cable is not included but you can ask us if you need it)
  • APOLLO X is powered directly from DB23 RGB female connector!
  • Multiple video resolutions available up to 1920 x 1200 key selectable
  • Available PAL or NTSC version (just ask me for APOLLO X PAL or APOLLO X NTSC)
  • Operating LED
  • Reset / screen resolution / video filter key selectable
APOLLO XS - Compatibility & Features (120€ + shipping)
  • Compatible with ALL AMIGA COMPUTERS that have S-video output!
  • APOLLO XS is available with S-video female or male connector...just write us in the order info for S-video Male or Female connector
  • APOLLO XS has a S-VIDEO input connector to be connected to your Amiga S-video output and a female DB15 HD panel connector to which you will have to connect the VGA cable to go to the monitor/TV (VGA cable not included). For the audio connection just connect your cable (2xRCA-jack) to your TV/monitor input (audio cable is not included but you can ask us if you need it)
  • APOLLO XS is powered by using standard USB cable (AC/DC converter is not included). So you can use a standard smartphone AC/DC adapter
  • PAL/NTSC compatible with automatic recognition
  • Operating LED
APOLLO XC - Compatibility & Features (120€ + shipping)
  • Compatible with ALL AMIGA COMPUTERS that have CVBS video output!
  • APOLLO XC is available with RCA female or male connector...just write us in the order info for S-video Male or Female connector. Only real and genuine 75Ohm video cable!
  • For example A600 / A1200 / CD32 have native CVBS video output..that's the perfect solution for you or you can choose also APOLLO X
  • Operating LED
FINAL NOTE
  • You are buying an exclusive and professional product for your Commodore AMIGA
  • The project is copy-protected. Any reproduction/resale/modification/copying is prohibited and will be prosecuted
  • APOLLO is guaranteed for 1 year. The guarantee is recognized only if in the event of fault/problem it will be received back with the SEAL intact (anti-tampering seal)
  • Envelope can be black or white according to my stock availability
Edit:
Same questions and some others
50Hz?
Scanlines?
Possible to set up custom resolution?
What chip or technology is it based on?
Possible to have hdmi out?
  1. To be clear..obviously it is upscaled to get 60/75Hz which is today's standard
  2. Scanlines?No..there are many systems that can be connected downstream
  3. 800X600 up to 1920x1200
  4. HPC (high performance chipset)
  5. I received many requests to have the VGA connection as it is very widespread, from old monitors / TVs up to the most modern ones
Edit:
Hi @axel81 ,
What exactly are the preset filters on the Apollo X ?
Hi there Watson
We often find ourselves in front of TVs/monitors which, despite having the color preset at 50%, have a different chromatic/luminous response.
So "preset" video filters are stored to give more or less hue/brightness/saturation/contrast to the image
In any case you ther isalso "normal" presert that is 50% for all components (saturation/contrast/ecc) and you can optimize locally on your TV/monitor
Can you provide some more details on the specs?
1. Can you set it to 640x480 for use on a CRT?
2. Does it support 50 Hz vertical refresh?
3. Does it do any deinterlacing / is there any lag?
50Hz?
Scanlines?
  1. from 800x600 @ 60HZ to 1920x1200 @60/75Hz
  2. upscaling to 60/75Hz
  3. No lag
50Hz?
Scanlines?
  1. 60/75Hz
Hi @axel81 ,
Hi @axel81 ,
Hi there Watson
Hey there,
quick question, since the vast majority of Amiga's are PAL 50hz, wouldn't it mean that by upscaling to 60 or 75hz this would introduce "shimmer" and "jitter" to scrolling that is usually smooth at 50hz?
Hey there,
Hi there
No..image is clear without any shimmer/flickering or something else.
Some pictures attached on the first post..as you can see form A600 and A500.
:) I think the issue only affects scrolling, not static images. The reason I ask is usually when a scandoubler outputs a different refresh rate to the input device then there are "missed frames" every few frames, which is only visible with smooth scrolling etc, but can be quite disconcerting.
I am far from an expert in the area, but it is something that comes up with scandoublers quite often. If you could link to a couple of videos showing smooth scrolling on a 50hz PAL Amiga going through the Apollo (preferably in 1080p and recorded in the native refresh rate that the Apollo is outputting at the time - either 60 or 75hz) it would be very helpful.
Ok I understand what you are referring to..now I don't remember if the GBS8200 has this problem..
But I had already seen APOLLO in function in the laboratory at 1080 connected both to the "UNITED" TV and then to a 32" "Sharp" but the motion picture (Lotus/Chuck Rock/Pinball Dreams/etc) was correct and no "missing frame" was visible :cool:
Could you please post photos of the inside to see what is it made of ?
thx
No probs, can you please link to a couple of videos showing a 50hz PAL Amiga smooth scrolling?
Thanks.
I got an AOC 24E1Q that does native 15khz over vga - however there's a limited set of controls.
I'm wondering if this Apollo box (either type) allows for fine tuning picture width (4:3 and so on?)
Seems like theres ghosting on text (looking at the kickstart screen), how does workbench look?
Yes..for example it is available 1024x768 that is 4:3
Edit:
First video posted..more videos coming soon
Uploaded two videos
The two videos you have uploaded have NO SCROLLING in them at all. They do not show anything of use.
You need to upload videos showing a 50hz PAL Amiga SCROLLING - for instance, the first level of Shadow Of The Beast, or Banshee or Project X or anything that shows full screen smooth scrolling.
Hope this helps.
