Hi all..
Hoping someone can help me understand if I'm doing something wrong or need new hardware.
I am currently finishing off an A1200 build with a new 1200.net case and TF1260. Indy MK3 installed as well as a Freeway ClockPort USB that is connected onto a clockport extender and works very well.
The problem I am having is no matter what connector on the extender I use I can not get the Amigakit RTC with temperature sensor to be seen by the Amiga.
If I connect the RTC to the original CP it works fine.
Any ideas ? Is my clockport which is the same as the link above Rev C not compatible or does the Amigakit rtc not work on any extender ?
Thanks for any help you can give
