Yellow screen normally means a bad FAST RAM expansion instead a CPU error.
Since this is a A2000 error, I can bet a few money on the PSU or the missing tick signal.
There's no RAM other than what's on the motherboard, and switching J300 doesn't make a difference.
For better or worse, it's now no longer intermittant: it's always yellow.
I'll check the power supply tomorrow; gotta do other stuff tonight. Is it anything other than metering the voltages under load?
Unfortunately for this 2000, I got an incredible deal on a truly amazing condition 3000... So, it'd better shape up soon, or it may spend a good long while non-working. :|
--Robert
Cheers!
Robert
---------- Post added 12th August 2012 at 00:06 ---------- Previous post was 11th August 2012 at 23:08 ----------
Aaaand: booo...
Checked the power supply under load. Everything read within +/- 0.1v of nominal. Need to break out the scope for the TICK line, but if the J300 is working right, that shouldn't matter, right?
Suggestions? RAM is all soldered on; not liking the idea of desoldering all of them.
Thanks!
Rober
