Anybody knows how to modify QuickShot 2 Turbo into 2-button joystick?
  • Thread starter Thread starter butjer1010
  • Replies Replies 15
  • Views Views 2277
butjer1010
Croatia
Moslavina
did anybody tried to "convert" QS II Turbo, or QS II plus to 2-button joystick? If someone knows how, I would be very gratefull to share his knowledge with me. I tried to play Flashback on my Amiga 1200 with "normal" joystick, but i cannot jump over "the big hole" at the end of the game. I tried solutions from net (combination of buttons and directions to make big jump), but that was very frustrating :) I have 7 QS II Turbo joysticks, and i would risk one to modify it to play Flashback normally (i have changed cables in few of them, so i have 2 free wires).
Thanks in advance
If (big IF) supported by the game, the 2nd fire button should be using pin 9, as the single fire buttons use pin 6, if I am not mistaken.
I have never done this myself, so please have someone else confirm this approach before proceeding with the modification.
Thanks a lot. Yes, i have already seen this posts with pin 9, but i don't know how to connect it to pin 9. I have also read that it needs, on some Joysticks, a 1000 Ohm resistor??? That's way i wanted to see if someone has already did it! :)
Thanks again
I know that Flashback supports 2 button joystick, it is in options to choose (1 or 2)
I have never updated this post, but 2nd button really works on pin 9!!!! If someone wants to convert QS or Competition pro, just connect one fire button to pin 9 on db9 connector!
If I remember correctly the 3 button mega drive controller would work if it does maybe get a broken mega controller and solder the quick shot buttons to the mega drive and use it to remap
You could also look at a cd32 controller circuit and use that as a guide
Hi, thanks for this post, but i wanted joystick with 2 button, not a gamepad. Don't know why, i'm one of the greatest player when i have joystick in hands, but i suck more than anybody with gamepad :) I was maybe too old when gamepads came to me :)
Yes, i tried convert MD gamepad to commodore, and i did it, it work, but as i said, joystick is my primary "weapon" :)
I never had a qs2 but I guess it has 2 buttons acting the same.
Maybe I have not completely understand but why don't you just separate them and connect one to the switch that activates the "up" position of the stick?
Yes, originally QS2 has 2 buttons that acts the same, but if You have cable with 9 wires, You can add one of those 2 button to pin 9, and You'll have 2-button Joystick! Some games like Flashback (my intention was this game - big jump :) ) can be used with 2-button joystick for extra controls :)
I thought flashback couldn't be used with 2 buttons joysticks, that's why you were searching for a solution.
I was a bit confused because pin 9 is the simple solution.
Yes, i found out that it is very simple solution, but i was not sure, that's way I asked here :)
I’m talking about still using the quick shot but soldering buttons to the joypad circuit and use it as an interface
I’m talking about still using the quick shot but soldering buttons to the joypad circuit and use it as an interface maybe also 3D print a new base to house it
Thanks in advance
Anyone else tried to modify other joysticks with 2 buttons successfully?
TIA
You can do that with every joystick that fits for commodore or amiga, just need cable with 9 wires. They are very cheap on ali....
