Anyone help with DevPac?
ptp170
R Tape loading error, 0:1
Devon
After a long journey and painful journey with a Chinon HD floppy (https://www.amibay.com/showthread.php?73920-Chinon-HD-drive-won-t-read-HD-floppies) I came across a thread here from Joe Fenton (http://www.amiga.org/forums/showthread.php?t=19858)
I am trying to assemble the source code in Joe's thread in DevPac. I've included 'system.gs' but the assembly fails on the CALLSYS lines returning 'Error instruction not recognised at line ### etc'.
Can anyone tell me what I'm doing wrong??
Chris
BLTCON0
Math inside
Hellas (Greece)
Chania, Crete
CALLSYS is not a standard instruction - maybe it's a custom written macro to make calling system functions easier. Since the function names are more or less self-explanatory, you could replace each CALLSYS instance with the equivalent
jsr _LVO{equivalent library function name here}(a6)
instruction.
All belong to exec.library except GetSysTime which belongs to timer.device, see RKM - Libraries & Devices.
Peeking into the relevant .i include files in Devpac may get you the associated EQU negative offsets, so you'd then just
jsr -$xyz(a6) or
jsr -XYZ(a6)
without needing _LVO translation, where -$xyz / -XYZ the relevant offset, depending if it's given in hex or dec format.
ptp170
Devon
instruction.
jsr -$xyz(a6) or
jsr -XYZ(a6)
So I'll need to dig out more include files if I use the jsr _LVO method? I've got a disk full of includes etc that I can use.
Sorry for the simplistic reply but this really is VERY alien to me.
Chris
BLTCON0
Math inside
Hellas (Greece)
Chania, Crete
Chris
It's alien to me too, my experience with Devpac was ages ago as a teen, and only coded hardware-hitting simple demos anyway. Not much interest in the OS. But in general _LVOxyz names are resolved at link time by amiga.lib, you should look into DevPac's documentation for more details (in fact I never used Devpac to produce linkable code, only directly executables).
Another approach is getting the offsets directly, they're in the offset reference table of RKM - Includes & Autodocs, although I'm not sure you'll find the DeviceList structure offset there.
Brian
Kentucky
Chris
Don't know if this will help, but I came across a macro definition for CALLSYS that looks reasonable. I've done very little Amiga development to date so I'm not sure if this is exactly what you need or not.
macro CALLSYS
xref _LVO\1
jsr _LVO\1(a6)
endm
Sardine
Staff member
Staff Moderator
Merseyside
Weleace Wodderwick.
what your name wapscallian
my name is brian
Bwian eh!!
no BRIAN ........ SLAP!!!! AHH!
:D
sorry i couldn't resist one of my favorite films :)
ptp170
Devon
Chris
macro CALLSYS
xref _LVO\1
jsr _LVO\1(a6)
endm
Have now got the following. Not sure if the Macro is inserted in the correct place? All 18 of the CALLSYS errors have disappeared but now I get:
Code:
source expired prematurely
Which according to the DevPac manual means: within an IF, MACRO or REPT and the source ran out.
:unsure:
Code:
; Universal Drive Patch
; Copyright (C) 1997 Joseph Fenton. All rights reserved.
        include /DriveIDCK/system.gs
        include dh0:devpac/include2.0/include/resources/disk.i
        include dh0:devpac/include2.0/include/exec/exec.i
        include dh0:devpac/include2.0/include/devices/timer.i
        output  c:udp
; note: this program cannot be run from WB
entry       bra.b   start
; Standard 2.x/3.x version string
        dc.b    0,'$VER: Universal Drive Patch 2.0 (3.6.97)',0
        CNOP    0,4
; The main program code.
start       movea.l 4.w,a6
CALLSYS MACRO
JSR _LVO\1(A6)
ENDM
        CALLSYS Forbid
; get memory for AE drive command function
        moveq   #4,d0
        move.l  #MEMF_CLEAR+MEMF_CHIP+MEMF_PUBLIC,d1
        cmpi.w  #39,LIB_VERSION(a6)
        blo.b   .ac         ; pre-39 was buggy in reverse
        ori.l   #MEMF_REVERSE,d1
.ac     CALLSYS AllocMem
        move.l  d0,ChipPtr
        bne.b   .ok0
        CALLSYS Permit
        move.l  #ERROR_NO_FREE_STORE,d0
        rts
; get memory for ReadUnitID patch code
.ok0        move.l  #CODE_LENGTH,d0
        move.l  #MEMF_CLEAR+MEMF_PUBLIC,d1
        blo.b   .af         ; pre-39 was buggy in reverse
.af     CALLSYS AllocMem
        move.l  d0,MemPtr
        bne.b   .ok1
        moveq   #4,d0
        movea.l ChipPtr,a1
        CALLSYS FreeMem
        CALLSYS Permit
        rts
; get timer.device base
.ok1        lea DeviceList(a6),a0
        lea timerName,a1
        CALLSYS FindName
        move.l  d0,TimerBase
        bne.b   .ok2
        movea.l MemPtr,a1
        CALLSYS FreeMem
        moveq   #4,d0
        movea.l ChipPtr,a1
        CALLSYS FreeMem
        CALLSYS Permit
        move.l  #RETURN_WARN,d0
        rts
; copy patch code into the allocated memory
.ok2        lea ReadUnitID,a0
        move.l  MemPtr,a1
        CALLSYS CopyMem
; get disk.resource base
        lea DskRsrcName,a1
        CALLSYS OpenResource
        tst.l   d0
        bne.b   .ok3
        movea.l MemPtr,a1
        CALLSYS FreeMem
        moveq   #4,d0
        movea.l ChipPtr,a1
        CALLSYS FreeMem
        CALLSYS Permit
        rts
; Patch disk.resource ReadUnitID() function.
; This is the system-friendly method!
.ok3        lea _LVOReadUnitID,a0   ; function offset
        movea.l d0,a1           ; library base
        move.l  MemPtr,d0       ; new function pointer
        CALLSYS SetFunction
; Exit leaving patch in memory. You don't have to 'run' this program.
        CALLSYS Permit
        moveq   #RETURN_OK,d0
        rts
        CNOP    0,4
MemPtr      dc.l    0
DskRsrcName dc.b    'disk.resource',0
        even
timerName   dc.b    'timer.device',0
        CNOP    0,4
; This is the new ReadUnitID() function.  It handles the disk identification
; and AEHD drive controlling.
ReadUnitID  movem.l d2-d3/a3,-(a7)
        move.l  d0,d2           ; unit number
        move.b  #8,d3
        lsl.b   d0,d3           ; drive select bit
        lea $30(a6),a0      ; unit id table
        lsl.l   #2,d0           ; offset for unit
        lea (a0,d0.w),a3        ; ptr to this unit id
        bsr.w   GetDriveID      ; get 32bit ID
        cmpi.l  #DRT_EMPTY,d0       ; drive present?
        bne.b   .1          ; yes, check for HD
        tst.l   d2          ; check unit number
        bne.b   .2          ; external, no drive
        moveq   #DRT_AMIGA,d0       ; assume internal present
.1      bsr.w   CheckDrive      ; check disk type
.2      move.l  d0,(a3)         ; set disk type
; Check for whether ReadUnitIDwas called from trackdisk.device. If not,
; simply exit back to the calling code.  If called from trackdisk, cleanup
; the stack, determine which setup vector to return in a1, and return to
; trackdisk at appropriate offset.
        movea.l 12(a7),a3       ; return address
        cmpi.l  #$2C5F4E75,(a3)     ; movea.l (a7)+,a6  rts
        bne.b   .4          ; not trackdisk
        movea.l 20(a7),a3       ; next return addr
        cmpi.w  #$B0AB,(a3)     ; cmp.l d16(a3),d0
; trackdisk is trying to determine the disk type
        movem.l (a7)+,d2-d3/a3
        addq.l  #4,a7           ; pop 1st return address
        movea.l (a7)+,a6
        movea.l (a7)+,a1        ; trackdisk return addr
; Determine structure offset for different versions of trackdisk. This
; allows the code to be mostly independent of the version of trackdisk.
; This works for versions 37 through 40.
        move.w  2(a1),d2        ; prev ID offset
        subi.w  #$54,d2         ; offset for this version
        cmp.l   $54(a3,d2.w),d0     ; same type as previously?
        bne.b   .3          ; no
        jmp (a1)            ; yes, return to trackdisk
; determine which setup routine is needed for this disk type
.3      pea $22(a1)         ; new return address
        lea SetupDD(pc),a1
        cmpi.l  #DRT_AMIGA,d0
        beq.b   .5          ; 3.5" DD
        lea SetupAE(pc),a1
        cmpi.l  #$0F03FFFF,d0
        beq.b   .5          ; AEHD drive in HD mode
        lea SetupHD(pc),a1
        cmpi.l  #DRT_150RPM,d0
        beq.b   .5          ; 3.5" HD
; not recognized, return and use previous disk type settings
        movea.l (a7)+,a1        ; return address
        lea 4-$22(a1),a1        ; branch if same address
        cmp.l   d0,d0           ; same as previous
        jmp (a1)
.4      movem.l (a7)+,d2-d3/a3
.5      rts
        CNOP    0,4
; Read the drive ID bits and set the AEHD speed select if needed.
GetDriveID  not.b   d3          ; drive select low
        lea $BFD100,a0
; turn motor on, then off to reset drive ID circuit
        move.b  #$7F,d0
        move.b  d0,(a0)         ; assert motor
        and.b   d3,d0
        move.b  d0,(a0)         ; select drive, motor on
        move.b  #$FF,(a0)       ; deassert motor
        move.b  d3,(a0)         ; select drive, motor off
        move.b  #$FF,(a0)       ; deselect drive
; read drive ID bits
        moveq   #31,d1          ; 32 bits
        moveq   #0,d0
.1      lsl.l   #1,d0
        btst    #5,$BFE001      ; get ID bit
        beq.b   .2
        bset    #0,d0
.2      move.b  #$FF,(a0)       ; deselect drive
        dbra    d1,.1           ; next bit
        not.b   d3          ; drive select high
        move.l  d0,d1
        andi.l  #$FF1FFFFF,d1       ; AEHD drive ID mask
        cmpi.l  #$0F03FFFF,d1       ; AEHD drive?
        beq.b   .3          ; yes
        rts
; AEHD drive - determine the disk type and set the drive speed.
.3      btst    #21,d0          ; disk type bit
        bne.w   AEHD            ; HD disk
        bra.w   AEDD            ; DD disk
        CNOP    0,4
; Determine if disk reported as DD is really HD by timing the track
; using the index pulse.
CheckDrive  cmpi.l  #DRT_AMIGA,d0       ; 3.5" DD?
        bne.w   .exit           ; no, exit
        beq.w   .exit           ; yes, exit
        lea $BFD000,a0
        move.b  #$7F,d2
        move.b  d2,$100(a0)     ; assert motor
        and.b   d3,d2
        move.b  d2,$100(a0)     ; select drive, motor on
        bsr.w   GetSystemTime
        move.l  d0,d2
        addi.l  #800,d2         ; .8 sec
.loop0      btst    #5,$1001(a0)        ; /RDY
        beq.b   .1          ; motor up to speed
        bsr.b   GetSystemTime
        cmp.l   d2,d0
        blt.b   .loop0          ; wait for motor to spin up
.1      tst.b   $D00(a0)        ; clear icr
        bsr.b   GetSystemTime
        move.l  d0,d2
        addi.l  #500,d2         ; .5 sec
.loop1      btst    #4,$D00(a0)     ; /INDEX = FLG bit in icr
        bne.b   .2          ; found index
        bsr.b   GetSystemTime
        cmp.l   d2,d0
        blt.b   .loop1          ; wait for index pulse
        bra.b   .dd         ; timeout
.2      move.l  d0,d2
.loop2      btst    #4,$D00(a0)     ; /INDEX = FLG bit in icr
        bne.b   .3          ; found index
        bsr.b   GetSystemTime
        cmp.l   d2,d0
        blt.b   .loop2          ; wait for index pulse
        bra.b   .dd         ; timeout
.3      sub.l   d0,d2           ; time left in .5 sec
        cmpi.l  #250,d2
        blt.b   .hd         ; took more than .25 sec
.dd     moveq   #DRT_AMIGA,d0       ; 3.5" DD
        bra.b   .4
.hd     move.l  #DRT_150RPM,d0
.4      not.b   d3          ; drive select high
        move.b  #$FF,$100(a0)       ; deselect drive
.exit       rts
        CNOP    0,4
GetSystemTime   movem.l d1/a0-a1/a6,-(a7)
        lea SysTime(pc),a0
        movea.l TimerBase(pc),a6
        CALLSYS GetSysTime
        lea SysTime(pc),a0
        move.l  #$FFFFF,d0
        and.l   (a0)+,d0        ; tv_secs & 000FFFFF
        mulu.w  #1000,d0        ; ms
        move.l  (a0),d1         ; tv_micro
        divu.w  #1000,d1        ; ms
        andi.l  #$FFFF,d1
        add.l   d1,d0           ; total ms
        movem.l (a7)+,d1/a0-a1/a6
        rts
        CNOP    0,4
; Set the AEHD drive to the proper speed for the disk type.
AEDD        moveq   #DRT_AMIGA,d0       ; 3.5" DD
        move.b  #$F9,d2         ; set DD speed opcode
        bra.b   SetAE
AEHD        move.l  d1,d0           ; AEHD drive in HD mode
        move.b  #$FB,d2         ; set HD speed opcode
SetAE       movem.l d0/a1,-(a7)
        lea $BFD000,a0
        lea $DFF000,a1
        move.b  d2,$100(a0)     ; speed
        and.b   d3,d2
        move.b  d2,$100(a0)     ; select drive, set speed
; write a longword of 0 to activate the AEHD setting
        move.w  #$4000,dsklen(a1)
        move.w  #$1002,intreq(a1)   ; clear disk ints
        move.l  ChipPtr(pc),dskpt(a1)
        move.w  #$C002,dsklen(a1)
        move.w  #$C002,dsklen(a1)   ; start write to set speed
; wait for DSKBLK
        move.l  #$20000,d2
.loop       move.w  intreqr(a1),d0      ; ints
        btst    #1,d0           ; DSKBLK
        bne.b   .1          ; done
        subq.l  #1,d2
        bne.b   .loop
; timeout, stop the DMA
.1      move.w  #$4000,dsklen(a1)   ; stop any disk DMA
        move.w  #2,intreq(a1)       ; clear DSKBLK
        movem.l (a7)+,d0/a1
        rts
        CNOP    0,4
; These routines setup the trackdisk variables needed to distinguish
; one format from another. They call a common track buffer setup.
SetupDD     move.l  #880*1024,$44(a3,d2.w)  ; total storage
        move.l  #300000,$50(a3,d2.w)    ; timeout
        move.w  #11,$4E(a3,d2.w)    ; # sec/trk
        move.w  #15296,$48(a3,d2.w) ; track length + overlap
        move.w  #13628,$4A(a3,d2.w) ; track length
        move.w  #1660,$4C(a3,d2.w)  ; gap length
        move.l  #DRT_AMIGA,$54(a3,d2.w) ; disk type
        move.b  #DRIVE3_5,$40(a3,d2.w)  ; drive type
        bra.b   SetupTrkBuffer
        CNOP    0,4
SetupAE     move.l  #1520*1024,$44(a3,d2.w) ; total storage
        move.l  #500000,$50(a3,d2.w)    ; timeout
        move.w  #19,$4E(a3,d2.w)    ; # sec/trk
        move.w  #24004,$48(a3,d2.w) ; track length + overlap
        move.w  #22334,$4A(a3,d2.w) ; track length
        move.w  #1662,$4C(a3,d2.w)  ; gap length
        move.l  #$0F03FFFF,$54(a3,d2.w) ; disk type
        move.b  #4,$40(a3,d2.w)     ; drive type
        CNOP    0,4
SetupHD     move.l  #1760*1024,$44(a3,d2.w) ; total storage
        move.l  #600000,$50(a3,d2.w)    ; timeout
        move.w  #22,$4E(a3,d2.w)    ; # sec/trk
        move.w  #30584,$48(a3,d2.w) ; track length + overlap
        move.w  #27256,$4A(a3,d2.w) ; track length
        move.w  #3320,$4C(a3,d2.w)  ; gap length
        move.l  #DRT_150RPM,$54(a3,d2.w) ; disk type
        move.b  #DRIVE3_5_150RPM,$40(a3,d2.w) ; drive type
SetupTrkBuffer  movea.l $68(a3,d2.w),a1     ; track buffer ptr
        move.w  #-1,(a1)        ; track invalid
        clr.b   2(a1)           ; clear track flags
        move.w  $4C(a3,d2.w),d0     ; gap length
        lea $68(a1,d0.w),a0
        adda.w  d2,a0
        adda.w  d2,a0           ; start of data area
        move.l  a0,4(a1)        ; track data ptr
        suba.w  d0,a0           ; start of gap area
        lsr.w   #2,d0           ; # longs in track gap
        subq.w  #1,d0           ; for dbra
        move.l  #$AAAAAAAA,d1       ; MFM zero value
.1      move.l  d1,(a0)+        ; clear track gap
        dbra    d0,.1
        rts
        CNOP    0,4
ChipPtr     dc.l    0
TimerBase   dc.l    0
SysTime     dc.l    0,0
CODE_END:
CODE_LENGTH equ CODE_END-ReadUnitID
end
ptp170
Devon
Put the macro definition before the code, i.e. before the
entry bra.b start
line
That did make a difference but now DevPac gives an slightly different error of: Error source expired prematurely in assembly options
Brian
Kentucky
Weleace Wodderwick.
my name is brian
Bwian eh!!
:D
Just don't throw me to the floor...
